Using Our Rockwood 2608BS With Slides In.
We got our Rockwood Ultralite 2608BS, the sister to your 26FKBS and are really enjoying it. We had the same concerns, but we were fortunate to actually be able to see the 2608BS in person and actually try getting in and out with the slides retracted. The only way into the bathroom is through the rear door, but I have bad knees and tend to be "a little overweight" and I have no problem getting in and out of the bathroom. With the slide retracted, we can also crawl onto the bed with no problem if we want to take a quick nap. The only drawback is that the switch for the FW pump is by the front door and reaching in through the front steps to reach it is not "user friendly". If you are getting a snack anyway while you are stopped there is no problem because you can get to the switch panel easily once you open the front steps. The kitchen is pretty much totally accessible except for the cabinets on the far left along the front wall.
As for the FW pump switch access, the pump is under the closet area and i'll be wiring a second switch mounted on the end wall of the closet right where you step up through the rear door so we will have water in the bathroom even if we don't go into the front part of the TT.
Enjoy your new TT, we sure are.
Paul & Sherida
Paul & Sherida Hodel and Coco Chanel, the Chocolate Cockapoo and the family's prized possession!
New TT: 2021 Rockwood Ultra Lite 2608BS, 570 watts of solar + 300 AH of Battle Borne lithium batteries.
TV: 2008 Chevy Silverado 1500
