I know exactly what your experiencing. I caught my slideout awning on a stop sign and pulled it out at the bottom and middle. Luckily, I had the entertainment center in that corner of the slide. I removed the fireplace and drilled completely through the same holes with a 1/4" bit and inserted 1/4" x 2-1/4 carriage bolts, 1/4" body washers, nylock nuts, and painted the bolt heads white, then reinstalled the fireplace. The bolts are not visible from the inside and if you don't look close to the outside you would never know.
Richard & Jill
