Old 10-19-2020, 09:07 PM   #1
grumpyer's Avatar
Black tank flush
Hi all. I have a Superlite 29rkws. Went to use the black tank flush for first time and water won't go in, At home tried to pump antifreeze in but only got sprayed with it coming out by connection. Am I doing something wrong? What gives?
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 10-20-2020, 08:56 AM   #2
You have likely experienced a bad anti-siphon/check valve. It's a fairly common problem.
Here are a couple of threads to check out.
https://www.forestriverforums.com/fo...sh-218617.html
https://www.forestriverforums.com/fo...sh-218964.html
https://www.forestriverforums.com/fo...4&pp=25&page=2
https://www.forestriverforums.com/fo...ng-214956.html
https://www.forestriverforums.com/fo...on-210582.html
https://www.forestriverforums.com/fo...ush-86736.html
Iwritecode is offline   Reply With Quote
Old 10-20-2020, 10:01 AM   #3
As mentioned, an often discussed topic.
Some have reported they are plumbed backwards from the factory.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-20-2020, 03:06 PM   #4
grumpyer's Avatar
After reading several posts I did what dealer suggested and replaced valve with a 90 elbow. Thanks all!
2015 F 150 max tow
black, black tank, black tank flush, flush, tank
