Thanks to all those fine suggestions
The final answer is - IT IS A TV Mount
I finally got back to the trailer after a several month hiatus for moving and checked the back of the TV inside. Lo and behold, it has a detachable mount that allows the whole tv to be unhooked and moved outside. The only problem is that all the cables are firmly cable-tied in place and would require some re-work to pry out the power cable. But be that as it may, I have no intention of ever moving the TV outside.
So that should be the end of discussion
