Old 07-14-2021, 09:21 PM   #1
chocking the tires
Hi all, We just purchased a used 2020 Flagstaff 529RLKS 5th wheel. We have a Keystone Cougar travel trailer (that is our trade in). We use the X-Chock for chocking the Cougar but the Flagstaff doesn't seem to have enough space between the tires. What does everyone use on their Flagstaffs?
alelka is offline   Reply With Quote
Old 07-14-2021, 09:41 PM   #2
jay2703's Avatar
Check out the One Step by Fastway.
https://www.fastwaytrailer.com/onestep-chock
2011 Rockwood Mini Lite 1809S
2013 Rockwood Ultra Lite 2304S
2004 Dodge Dakota SLT+ 4.7
2012 Ford F150 FX4 3.5 EcoBoost
jay2703 is offline   Reply With Quote
Old 07-14-2021, 09:47 PM   #3
There are two different models of X-Chocks; one of them is made for the narrower space between the tires. This is the one we have for our Flagstaff 21DS: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 07-14-2021, 10:08 PM   #4
Wow that looks way easier! Thanks
Old 07-15-2021, 02:24 PM   #5
As mentioned there are two sizes of X-Chocks. Regular and X-Tended for spread axles.
I use the narrower (regular) style on mine and even then, I have to crank them tightly closed with the wrench for them to fit it between the tires on our Flagstaff 8509IKBS.
BAL says it will retract to 1-3/8" (between tires) and I have just barely that but I can get it in.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 07-16-2021, 11:21 AM   #6
While looking at the links provided this came up. This looks super easy. I have such a hard time using the wrench on these.
https://www.amazon.com/dp/B0951VC67R...xpY2s9dHJ1ZQ==
Old 07-16-2021, 12:28 PM   #7
grege's Avatar
Those look pretty easy to use.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 07-16-2021, 12:44 PM   #8
SailorSam20500's Avatar
I also use the One Steps. I stopped using the x-chocks I had, didn't really add much if any stabilization and were a pain to install and remove.
Setting up the OneSteps takes a bit of experimentation to get the correct spread, but you only do that once.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 07-16-2021, 12:50 PM   #9
nomad297's Avatar
I don’t have any experience with the One Step. I’m wondering how good of a job they do on soft ground or sand.
Bruce
Old 07-16-2021, 01:15 PM   #10
I have the One Step. I think if you were on really soft ground you might need a board under both sides depending on how long you're going to be set up. I have noticed them sink in a little bit when the camper is set up at home for fairly long stretches.
2018 Wolfpack 24PACK14+
2008 Toyota Tundra
2017 HD Limited
smkauffman is offline   Reply With Quote
Old 07-16-2021, 01:26 PM   #11
I've had mine in place where I store my trailer. Ground is mostly sand. Chocks have always seemed firmly in place come spring.
Al
tire, tires
