01-07-2021, 12:16 PM
cracking at furnace exterior
Has anyone experienced cracks at the furnace exterior vent on a 2016 8528IKWS?
01-08-2021, 10:11 AM
that to me looks like a stress crack. I would stop drill the crack to keep them from traveling.
Retired Navy
2016 Flagstaff 26 FKWS
01-08-2021, 10:22 AM
WOW! Interesting but a bummer.
The only things I could think of that might cause that are:
1. The furnace is somehow loose (not screwed down properly) and flexing/slamming against the intake/exhaust ports when traveling.
2. The furnace box 'typically' just slides onto the intake/exhaust ports for assembly/removal. If somehow the intake/exhaust ports have rusted fast to the furnace, expansion/contraction when the furnace runs/cools could be flexing the wall.
3. Something has hit/bumped the intake/exhaust.
All three are somewhat longshots but what is happening certainly isn't normal.
01-08-2021, 10:23 AM
I would gain access to the furnace from inside and see if the furnace bottom is properly supported. If the furnace or the floor under it is not supported, it could be moving during travel and flexing the outer wall that it’s attached to.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
01-08-2021, 10:29 AM
Has this happen after you installed the bug screens? If yes might, it be restricting exhaust flow and metal is over expanding and stressing wall.
Fonzie
01-08-2021, 11:00 AM
I have had the same bug screens installed on my 16 Surveyor for about a year after I purchased it new and I do not have any issues like what you have.
01-09-2021, 01:03 AM
Thanks if all else fails I will do this before I move it again.
01-09-2021, 01:04 AM
I will get into this on Sunday if the weather holds and let you know what I find.
01-09-2021, 01:06 AM
The screens have been on there for four years and it just showed up early last year.
01-09-2021, 09:50 AM
If you quote the post you are answering, the rest of us can follow along in your mind and know what you are referencing.
01-13-2021, 10:29 PM
I checked out how it is help in place and found it to be solid. I did not find anything that would have cause this but since I haven't moved it the size has not increased. I guess drilling the crack to stop it may be the only option.
