Electric brake short E-Pro 19FD
I received a brake short message from my brake controller this past week on our 2018 E-Pro. I traced the problem to a pinched wire on top of the axle pinched by the fresh water tank support.
I would suggest that if your wiring is strapped to the top of the axel that you check it as this could cause a failure of the system!
I repaired and moved my wire to the side of the axle at the pinch points.
I'll try to post photos later.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe"
