Old 04-25-2021, 10:13 AM   #1
Electrical Problem E-Pro 19fds
Last week while camping, we were hooked up to electric. I ran the electric heater all night without problems. In the morning, without thinking, I plugged the coffee maker in to the same GFI plug and puff. No more power. I went to the fuse box and toggled the thirty amp breaker as well as the GFI breaker , but the GFI would not reset at the plug. I checked the inverter and it had not tripped. I replaced the main GFI plug and still nothing. What am I missing?
Frank L is offline   Reply With Quote
Old 04-25-2021, 11:02 AM   #2
The breaker at the power pole the trailer is plugged into?
NavyLCDR is offline   Reply With Quote
Old 04-25-2021, 12:30 PM   #3
Do you have 120v power at other places in your R/V?
Have you checked voltage anywhere with a multimeter?
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 04-25-2021, 06:16 PM   #4
Yes. Frig and microwave are both working fine.
Old 04-25-2021, 06:17 PM   #5
Yes refrigerator and microwave are both working. Just outlets. No electric detected at any of the six outlets.
Old 04-25-2021, 06:55 PM   #6
The GFCI receptacle will not reset if it does not have power to it, so I would recommend you double check the circuit breakers in your power distribution center and make sure none of them is actually tripped.
Old 04-25-2021, 07:10 PM   #7
You said you replaced the "main GFI plug." (your words)
I assume you mean the GFCI receptacle?
When you replaced it, was there voltage there?
Did you test with a multimeter?
Old 04-26-2021, 06:53 AM   #8
There was no power there
Old 04-26-2021, 07:45 AM   #9
OK... then you will need to go back to the power distribution box in your R/V and check for power at the breaker that feeds that outlet and check for voltage.
If you have no power coming out of the breaker (and you are sure it is on) then the breaker is bad or not latched properly into the buss since you mention having power other places.
If you have power coming out the breaker and the feed wire is attached to the breaker properly, then you have an issue somewhere between the breaker and the GFCI outlet.
One last thing... this is a 30a shore power service correct?
Old 04-26-2021, 07:50 AM   #10
PhilFromMaine's Avatar
If you have power everywhere except the the GFCI circuit, then it is probably your circuit breaker for the GFCI circuit. You overloaded the GFCI line and that would trip the circuit breaker, not necessarily the GFCI. Play with the breaker reset some more. If that doesn't work, get out the multimeter and get some readings coming into the circuit breaker and out of the circuit breaker.
Sometimes the breakers look like they are engaged, but they really aren't. This should have nothing to do with your inverter if you are plugged into shore power.
PhilFromMaine is offline   Reply With Quote
Old 04-26-2021, 02:35 PM   #11
Make sure you flip all the breakers to the OFF position before you flip it back to the ON position first. Breakers need to be reset to reconnect the power. Even though it may seem as if it's reset it's not internally. This is common and is normal operation.
MasterElectrican787 is offline   Reply With Quote
Old 04-26-2021, 03:49 PM   #12
Trailer Park Supervisor
NJKris's Avatar
You need to reset the breaker on the inverter. Happened to me.
NJKris is offline   Reply With Quote
Old 04-27-2021, 09:17 AM   #13
Do you have a second GFI breaker that could be tripped? You may have one outside or in the bathroom.
dave1650 is offline   Reply With Quote
Old 04-28-2021, 09:33 PM   #14
That is the conclusion that I have come to. My only problem is that I can't find a reset switch.
Old 04-28-2021, 09:52 PM   #15
Hi Frank,
From another fellow e-pro owner:
The epros have a power inverter that has a reset switch on it. It is red.
The GFI runs through the inverter. So, until you reset the switch on the inverter, your GFI will never work.
Many of us epro owners have had this issue.
This is the fix you need.
2019 Flagstaff E-Pro 14FK
JS Stanley is offline   Reply With Quote
electric, electrical
