Fifth Wheel Heater Wiring
I bought a 2021 Flagstaff fifth wheel and after bringing it home and going through the systems everything worked fine except that I could not get the heater to work. The heater itself is difficult to access but I found and on/off switch that I changed position and it still wouldn't fire up. After checking propane flow throughout the camper and trying various other things, my neighbor (an RV owner) suggested that I look at the thermostat and we found that the heater had never been wired to the thermostat. After connecting the 2 white wires with a wire nut the problem was solved.
Today, the same neighbor brought home a 2022 Rockwood 5th wheel (made in the same factory as the Flagstaff) and after having experienced my problem with the heater, he checked his new rig to find out that the 2 white wires in the thermostat also had not been wired together.
My questions are, is this common in Rockwood/Flagstaff units and can anyone think of a reason that the factory would not properly wire the heater to the thermostat? Just a curiosity.
2021 Flagstaff 528RWS
2020 GMC 2500HD Diesel
2019 Labrador Retriever
1983 Wife
