Which model do you have? There should be an info screen that will show you the voltage and the current flowing into the battery. There should also be an info screen that shows you the accumulated amp-hours (Ah) that have been provided over the course of the present day. Some models will also show you amp-hour history for the past several days. You need to look at the operator's manual for your specific model.
Be aware that the current displayed, and the accumulated amp-hours, will not actually all be going into the battery. The numbers represent what has flowed out of the SCC onto the 12VDC bus, and some of that power would have been consumed by other 12V things in the RV - lights, fridge, etc.
If the power consumption in the RV is more than what the solar is providing, then the additional current to power those things will be drawn out of the battery. If the solar is providing more current than the RV is using, then the surplus current will flow into the battery. So, using the numbers displayed by the solar charging controller (SCC) to guess at the real state of the battery is not very accurate.
2023 r-pod RP-192 with Beast Mode suspension
600W rooftop solar, 300Ah LiFePO4 battery bank, 2000W inverter.
Uses an electric coffee maker when boondocking.
"Never underestimate the power of human stupidity."
-Lazarus Long
