04-20-2021, 04:30 PM
Has anybody got a wiring diagram ?
And an exploded view of 2019 Epro 19fd?
I am trying to customize my trailer but I would prefer not to go in blind like I did removing the murphy bed.
04-20-2021, 04:46 PM
There is no wiring diagram for any of the FR travel trailers. There is barely any uniformity of wiring between any two trailers.
What exactly are you trying to accomplish?
Maybe a specific question will get a specific answer.
2014 Shamrock 183
04-20-2021, 04:51 PM
Actually I was just trying to sort what wires run where, roof, floor, walls.
It's really unfortunate there is so little documentation on these things. Basically one is forced to just go hunting.
A clue I suppose is the master switch box for lighting that implies they are all in series.
Oh well, nothing is ever easy.
Doesn't exist
04-20-2021, 05:00 PM
Each and every RV seems to be Unique unto itself. No two are the same.
Brian & Becky
2018 Avenger ATI 27RBS
04-20-2021, 05:01 PM
The most important wires are the ones from the tow vehicle plug, to the brakes and to the battery.
First I would attempt to understand the electrical system, the DC side and the AC side.
The converter that makes 12 VDC from the outside shore plug to power 12VDC items like radio, lights, the furnace and charge the battery. THe 120VAC inside and outside usually has 1 GFI hooked in series to multiple plugs. THe electrical power panel has AC fuses like your house and DC fuses like your car.
check out youtube videos on that subject
other resources here...
https://www.forestriverforums.com/fo...like-1083.html
2014 Shamrock 183
04-20-2021, 05:13 PM
Thanks.
04-20-2021, 05:29 PM
Just as confused as you
rsdata should have said "The electrical power panel has AC breakers like your house and DC fuses like your car."
Richard & Jill
04-21-2021, 02:20 PM
Forest River will not supply you with a diagram, they said and I was told this on a tour. It depends on who worked on the line that day, only people who will supply a diagram is Coachmen.
Coachmen M/H
Concord
2018 / 300 DSC
04-21-2021, 02:26 PM
Well if I have to tear too much apart I am going to put it back together with actual wood panels. Just depends on how deep I have to go I guess. I got some old cherry and oak been waiting on a use for.
Beginning to be unhappy with this thing. Mostly as a result of a complete lack of documentation.
Hell, my Yukon came with a 500 page users manual and all I had to buy was a Chilton's.
Good thing these folks aren't in the transmission business!
[emoji106]
04-21-2021, 02:39 PM
Georgia Rally Coordinator
wiring diagram whats that. And now you know the rest of the story. Good luck on your rewire. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-21-2021, 02:42 PM
Ty
04-21-2021, 02:56 PM
Just some input if you want...
I completely rewired my solar system and other interior components in my rig. I created my own wiring diagram & schematic for the next time I need to trace wires, or drop it off at a RV shop for work, or a new owner if I sell it.
Might be something you want to do when you embark on your project.. then you have your diagram.
Best of luck -
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
04-21-2021, 03:00 PM
Actually, your thinking is sort of mine. Unless I pull back the covers and take a look I have zero idea what's under there PLUS if there is space for insulation it sure could use some.
Question is just how deep do I wanna go, a facelift or a radical hysterectomy! [emoji1787][emoji529]
04-21-2021, 03:06 PM
Well what a conundrum , if it were me, a facelift so you can enjoy your rig and camp RV More.
Less chance of breaking off some trim or other item that you wont be able to match or locate.
Little bits at a time. So over time you should get your chance to look in every nook and cranny when things go bad or you need to repair something.
Days Camping
