Old 04-17-2021, 10:17 AM   #1
ddubu's Avatar
How level is level
Hey guys, how level do I need to get my 5er so everything works right, fridge and slides? And where is a good reference point to check level? I can't get to the frame because of insulation, I get different readings from floor and solid surface counter and the rear bumper doesn't look like it was attached with much attention to level. Running a 2016 8529RLBS 35'.
Livin' the dream
2016 8529RLBS Flagstaff 35'
2016 F250 6.7L Powerstroke
ddubu is offline   Reply With Quote
Old 04-17-2021, 10:21 AM   #2
Just as confused as you
Scrapper's Avatar
I've heard that 5 to 6 degrees off is fine but the fact is if you can lay on the bed or floor without the feeling of rolling then your good.
Richard & Jill
Camping since 1989
Everyone gets confused at some time, some are better at hiding it than others.
Old 04-17-2021, 10:26 AM   #3
Just Tryin' to Help
cboss's Avatar
X2. And get a Level Mate. It makes leveling easier.
https://www.amazon.com/LogicBlue-Tec.../dp/B083ZMZPR8
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 1042
cboss is offline   Reply With Quote
Old 04-17-2021, 10:39 AM   #4
bubbles's Avatar
If you have internal doors open them up and see if they stay where you open them up to. If it feels level to you that should be good to go.
Old 04-17-2021, 10:48 AM   #5
PhilFromMaine's Avatar
I define RV level as what my adjusted torpedo level says it is. My prior measurements have always been on top of my refrigerator because I have always thought of it as the most level sensitive thing in my trailer. I agree that plus or minus 5 degrees is is okay.
My new to me TT has built in tube levels at the front of the TT at the trailer nose.
PhilFromMaine is offline   Reply With Quote
Old 04-17-2021, 11:20 AM   #6
NMWildcat's Avatar
Truth is, RV level depends on what feels good to you.
You can put a level in multiple places in/on your RV and chances are none of them will agree. Some folks use bumpers, frames, counter tops, floors, fridge, bed, etc.
I have never worried about how level the fridge is. If I can walk around my RV and it feels fairly level, the fridge is good. I have left my RV very unlevel for a few days with the fridge on and never had any problems.
As far as slides, I do like to be level and stabilized before moving them out, but will move them out occasionally while still hooked to the truck at a stop during travel days if the truck/trailer are both on a fairly level surface. We have to move a small slide out to access the bedroom.
I set my zero point level for the auto levelers by the levelness of the main floor where I walk most of the time. And even that floor, from one end to the other, isn't the same.
Bottom line, don't drive yourself nuts trying to perfectly level your RV from end to end. It just won't happen
Scott and Liz - Southern NM
Old 04-17-2021, 11:39 AM   #7
I never leveled. I always set my TT's to make the runoff from the AC unit go to the Left front or Left rear of TT, depending on where we set up.
TheWolfPaq82 is offline   Reply With Quote
Old 04-17-2021, 11:49 AM   #8
rsdata's Avatar
X2 plus adjust to get the AC or rain drip off the roof away from you as TheWolfPaq82 suggests...
see if your fried egg stays in the fry pan long enough or just rolls out of the pan...
2014 Shamrock 183
Old 04-17-2021, 11:55 AM   #9
LOL ! Can't argue with that logic.
Old 04-17-2021, 12:11 PM   #10
I put the level on the countertop. I don't want things rolling around when preparing food.
The floor and the countertop are the same as far as I can measure. They don't quite agree with the hitch so I need to remember the offset to keep from running back and forth.
I use the Andersen level blocks so I don't need to add or subtract blocks for getting the side to side level.
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is offline   Reply With Quote
Old 04-17-2021, 12:15 PM   #11
Happycamper
i just got some square pencils and now "mostly level" is ok. never had a problem with things working.
fkovach1 is offline   Reply With Quote
Old 04-17-2021, 12:17 PM   #12
ddubu's Avatar
Overthinking it I guess
Thanks for all the comments. Maybe I'm just overthinking the whole process. I've thought about using a trick we did when we were house flipping to check floors and foundations by just rolling a shooter marble and see where it goes.
Livin' the dream
Old 04-17-2021, 12:23 PM   #13
Blackrock's Avatar
I have a bubble level app on my phone and I place it on the floor just inside the door plus I have two of those cheap stick on rv levels, one on the rear bumper and one for fore and aft right close to the front jack switch.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 04-17-2021, 12:48 PM   #14
Mtnman64's Avatar
level
I have determined that my stove top and fridge are about the same. So the large round bubble level placed on the stove top with the bubble mostly in center gets the job done for me.
Mtnman64 is offline   Reply With Quote
Old 04-17-2021, 01:03 PM   #15
RVPP's Avatar
Level
I use a 3 foot level on top of the 'diamond plate' on the front of my RV and the top of the pass-thru on the side. Works like a charm.
Paul
This is not a rehearsal.
RVPP is offline   Reply With Quote
Old 04-17-2021, 01:17 PM   #16
Dahagen
If my bathroom door doesnt slam shut, I'm OK.
dahagen is offline   Reply With Quote
Old 04-17-2021, 01:48 PM   #17
AKA: 'tiredTeacher
awellis3's Avatar
Agreed. I use a level set on my cast iron griddle.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 04-17-2021, 01:58 PM   #18
I like to make sure no matter what that my bathroom door will slightly swing to a sort of closed position, hate it when it swings open on me))
sjbuzz54 is offline   Reply With Quote
Old 04-17-2021, 02:00 PM   #19
I like the bathroom door to slowly swing shut, life is better that way))
Old 04-17-2021, 03:37 PM   #20
MCTroy
This looks interesting and could save a lot of time when parking. No more, oops not level moments.
Do you have one installed? How did you power it? Reading user's manual it sounds like it could run off the trailer battery?
MCTroy is offline   Reply With Quote
