04-06-2021, 10:20 AM
#21
Originally Posted by boeingav8r
I like this idea �� a lot. I’m going to pull the pin and pull the trailer forward. The brakes should be applied.
But if I wanted to know for sure that all four brakes are working under normal circumstances with the emergency brake pin IN then I would need to jack it up, spin a tire and hit the truck brake pedal. I agree if they work with the truck brake pedal then they will work with the emergency brake switch pulled because I have verified that the emergency brake switch is good.
Yes, to a degree.
Some brake controllers (not all) use inertia (when slowing down) to add to the amount of proportion to apply the brakes. You can't simulate that setting still but you will be able to tell if all 4 wheels are getting some braking.
04-06-2021, 10:22 AM
#22
Originally Posted by NJKris
Does the breakaway switch 'lock up' the trailer brakes, or does it apply just enough braking power to quickly stop the roll?
Full on and lock up if the the trailer isn't moving too fast!
Only the brake controller proportionally applies enough current to apply the trailer brakes for the amount of brake pressure needed.
When you pull the pin it is full on brakes!
04-06-2021, 10:31 AM
#23
Originally Posted by Chuck_S
Someone may have covered it but it deserves to be highlighted.
Sorry, THIS IS WRONG!
The emergency brake should only activate in the event of a complete disconnect from the tow vehicle. It's a last resort after failure of the coupler and chains. If just the coupler fails the chains and power cable will handle the trailer brakes in a controlled fashion.
The brakes are not there to save the trailer -- it's too late for that if it comes completely disconnected. They're there to stop the runaway trailer as soon as possible. Trailer will probably be wrecked but is less likely to injure something or somebody after it's disconnected.
Trailer power cord should be longer than the chains so the brakes can be used even if only the chains connect the trailer. If the chains fail the power cord is coming out "automatically." Emergency brake cable should be longer than the cord and chains so it's the last thing that deploys.
-- Chuck
I quoted this post because it this is exceptional advice and everyone should read it again.
You DO NOT want the emergency brake pin pulling out when the R/V is still attached to the tow vehicle by just the safety chains. I have witnessed two times a trailer's emergency brake pin was pulled while still attached by the safety chains and in both cases it wrecked the tow vehicle.
A trailer will do some wild maneuvers when the pin is pulled and the brakes try to lock up fully as the trailer is moving at more than just a very slow speed. Since the magnets/shoes/drums/adjustment of each wheel can be somewhat different, the application of the brakes to each wheel can also be different, causing severe sway and excessive pulling from side to side. It will wreck things in a hurry!
04-06-2021, 01:24 PM
#24
On gravel or sand
Originally Posted by wanderingbob
Hitch up correctly , pull pin , get in truck , pull forward , trailer should stop truck in 10 feet or so !.. PUT PIN BACK IN !
Do this on gravel or sand. Check out the drag marks on the ground when you are done.
If it's a double axle trailer, only pull forward a foot or so, so marks from the first tire aren't obscured by the second tire. Or do a second test backing up.
Larry
04-06-2021, 02:06 PM
#25
Hi. At this point I have verified that the emergency switch is good. And the way it’s wired if the brakes are working through the truck they will work through that switch. My truck has a built-in brake controller on the dash and when I got the trailer I got going about 25 miles an hour and pushed the manual lever all the way over and you could definitely tell the trailer was braking. That’s how you determine how much gain you want to set it at. The manual tells me to get going 25 miles an hour and slam the manual break application lever all the way over and if the trailer brakes skid the tires then you know you don’t want to set it at max gain. But if the trailer tires don’t skid, then what should I set the gain at? When I rented the Winnebago in February I kept the gain at 10. But I don’t think that was right to do. I set the gain at 6 or 7 when towing mine and it seemed fine.
Whether or not it's a beautiful day has nothing to do with what it's like outside.
2022 Flagstaff MicroLite 25BRDS
2018 Silverado 1500 LT Ext Cab 5.3L 4WD 3.42 gears Auto/Manual Transmission. Z82 and Z85 pkgs.
