07-17-2020, 08:53 PM
I just can't unsee it !!!!!!!!!!!!!!!
I was putting a coat of wax on my 2018 Superlite 29RKWS . On the slide where the topper attaches to the side wall, I found a small crack about an inch long at the end of the bracket. (probably due to overtightening)
So do I.....
1. pretend I did not see it? ( not an option)
2. run some caulk on it & keep an eye on it?
3. drill small hole at end of crack & caulk?
4. just leave it?
Wish I had a picture of it but getting to dark
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
07-17-2020, 09:35 PM
Caulk it and forget it
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
07-17-2020, 09:48 PM
#3 would be my guess. Can I use a lifeline?
John
2003 1500 Avalanche 444,000 miles
2011 Rockwood ROO 23SS
07-17-2020, 09:57 PM
Door #2 .
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
07-18-2020, 06:50 AM
Bruce
07-18-2020, 07:02 AM
Part-Time Campground Host
#3 so the crack can't spread.
Craig & Cath
Days camped since 2015(retirement): 1687
07-18-2020, 10:22 AM
#3 instead caulk i would get clear epoxy.
07-18-2020, 10:39 AM
Clear epoxy and then never look up there again.
Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
07-18-2020, 10:47 AM
Hot Dog Slayer
So do I.....
4. just leave it?
I was stuck on this part.........I admire anybody who spends the time to wash and wax their vehicles. For some reason I just can't get into it.
As for your dilemma.......I couldn't do #1 either, so I would go with #3.
Two roads diverged in a wood and I took the one less traveled by.......now try backing your trailer out of that one!
2016 Forest River Microlite 21DS
2019 Ram 1500 Pearl Red Limited
07-18-2020, 11:39 AM
So it looks like the epoxy. Do I still need to drill hole?
2015 F 150 max tow
07-18-2020, 12:43 PM
If not for the wash & wax I would never have seen it!
2015 F 150 max tow
07-18-2020, 12:53 PM
I would do it doesn’t grow with flex on the road.
07-18-2020, 12:57 PM
"Curmudgeon"
Dicor, Eternabond, declare victory!
_____________________
TrawlerPhil
2014 Flagstaff Classic Ultralite 8528RKWS
2018 F-150 4X4 Max tow EcoBoost 3.5
2020 Tesla Model Y
07-18-2020, 01:11 PM
Definitely #3
07-18-2020, 01:21 PM
Yes i would like other reply said keep from growing from flexing when towing.
07-18-2020, 01:22 PM
So do I.....
4. just leave it?
Normally without a doubt I would do #3 first and then #2. However, I have questions. Was this from something done at the factory or dealer and is you coach still under the last bit of warranty? Obviously if under warranty, get it fixed if not then...
07-18-2020, 02:54 PM
#3 Stop Drill It, thats what they do on Aircraft Skin then seal it.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
07-18-2020, 03:05 PM
This is precisely correct. By carefully drilling right at the end of the crack you take all the stress that was focused on that TINY point where both halves come together. Those stresses are what causes the crack to run.
By drilling the hole it spreads the stress out in the entire circle of the drilled hole and the crack stops "growing"
The fact you used the term "stop drill" told me you were in aviation in the US Military. Civilians don't seem to use that exact phrase. *S*
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
Out of warranty! Don't know if factory installed or dealer. its 2018 I bought used lat fall
2015 F 150 max tow
07-18-2020, 03:08 PM
That is very correct, 24 years Navy on F-4's, F-14's and F-18's. E-9.
2016 Jeep Willys JK
USN-RET/DOD-RET
