Originally Posted by 5picker
Most manufacturers will say level first then deploy slides.
Some of that is a CYA statement and certainly there is 'some' truth to it.
As long as you are not on a severe twist (of the frame) when parked I have no hesitations opening/closing the slides. Look how many slides are open on the dealer lot with the R/Vs setting in every position imaginable.
I do try to level 1st and then deploy but I've also never been so out of level when camped for the night/rest area (remaining hooked-up) that I thought there'd be issues opening the slides. You'd likely roll out of bed if you were that unlevel!
Remeber three points won't have any twisting (tongue,, and each side of camper) just make sure you don't have a rock, root, hole, or anything else under one of you tires if you have tandem axle trailer.
