So, I drained the hot water tank and blew air through the system in preparation for storing my trailer and found where water had apparently wicked into the thin plywood inside the hot water tank access door. I followed the dampness along the floor to the back where hot and cold water lines connect to a tee and saw what appears to be wet wood below (second photo).
In the event that the crimp on fittings are leaking, how would I get access to that connection to repair it? The only way appears to be from the outside where I drained the hot water tank.
Any help would be greatly appreciated.
Thanks!
