Old 03-22-2024, 02:52 PM   #1
Poor 25FKBS design
We have a 2023 25FKBS. We love the unit. After having a 25fks we decided to upgrade. One complaint I have is the power/water service entrance. For some very over sighted and stupid reason, the water (ALL) comes into the camper OVER the electrical connection. Being a retied electrical engineer and having studied the NFPA for years this just doesn't make sense. At the very least, I'm surprised Forest river didn't recall these. At the very most, I'm surprised the hasn't been an accident and/or law suit
Name:	Flagstaff_Service entrance.jpg
Roadworthy is offline   Reply With Quote
Old 03-22-2024, 04:43 PM   #2
Does seem strange to see that but I am in my camper right now with the same electrical connection in a good rain storm. Just a flapper above the cord. My water is up front.
No problems.
And the cord that attaches to it is hanging on a partially open pedestal with the surge protector to cord connection hanging below it exposed to the rain.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 03-23-2024, 07:27 AM   #3
I can see the water dripping from your fresh water hose connection in the pic. That shouldn't happen. Suggest you get a 90 degree elbow for your fresh water hose that should take the stress off the hose fitting. Also wrap the male ends of the water hose and elbow with plumbers teflon tape when you put it all together and that should eliminate the dripping.
Old 03-23-2024, 07:35 AM   #4
Originally Posted by Wiscampsin View Post
Suggest you get a 90 degree elbow for your fresh water hose. It won't help with your power/water service entrance concern but will take the stress of the hose fitting.
x2
2022 Rockwood 2511S
Old 03-23-2024, 08:44 AM   #5
Get a 90 or a 45 for your water hose. Tape and tighten them, and you should be good. I'd have everything connected then turn the water on at the park/city connection, then the power. Your power connection is gasketted and has a ring to tighten it to the trailer. It's a similar scenario as packing up in the rain.
Camped: 2024 (Days/Nights) - 33/27
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 03-23-2024, 08:49 AM   #6
At shows, we've seen several models like that and not just Forest River.
I guess I don't understand the concern. Water shouldn't be leaking out of any of those hose connections and if it is, you need to address that. I'd be more worried about the water leak that's likely to travel back through the city water connection where it comes through that plastic panel. That's a known leak spot for water getting inside and down the wall.
And as mentioned, the electrical connection gets plenty of water on it during rain storms.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 04-15-2024, 09:15 PM   #7
I was thinking of the same thing this past weekend. I just took a little slower pace and made sure the electrical outlet was screwed on correctly. ( Now that thing is a PITA) I never get it screwed on right the first time. But I too have the 90 degree elbow and turn it to one side to avoid possible drips. I do hook the electrical up first then the water lines. That way I have nothing to interfere with the E cord installation. If the E outlet is on correctly I don't worry too much about the waterlines.
Deans25BRDS is offline   Reply With Quote
Old 05-09-2024, 07:16 PM   #8
Not sure what the big deal is....you have hose connected to tank flush, so city water is to left bottom
2024 Flagstaff MircoLite 25FKBS
2021 Chevy Silverado 5.3
Traveling with (2) pups Molly & Samie
boomer101 is offline   Reply With Quote
Old 05-09-2024, 07:26 PM   #9
its the puddle that you are standing in that makes things much worse
more people electrocuted with bare feet..... than gumboots
gotta say that layout is kinda stupid...
I'm betting the design was meant for trailers going to Aussieland
You can find some better cover to protect it from too much water/rain
marine vent covers work good
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
