Old 08-15-2020, 07:07 PM   #1
Screws into walls
I've got a 2021 26fkbs and was wondering what length screws should be used when mounting something to a wall. Are shields necessary for good hold?
Anything else to consider/avoid?
Thanks.
BTW, I live this trailer - I can't think of anything negative at all to say about it.
JPeebles is offline   Reply With Quote
Old 08-15-2020, 07:15 PM   #2
Part-Time Campground Host
cboss's Avatar
It depends on what you are mounting to the wall.
Your walls are maybe 2" or so and mostly styrofoam.
We use things to "stick" things to the walls instead of screwing things in.
There are plenty of threads here about how to do this.
Craig & Cath
Days camped since 2015(retirement): 1680
cboss is offline   Reply With Quote
Old 08-15-2020, 07:29 PM   #3
Oaklevel's Avatar
Be careful too long of screw may end up showing outside the trailer. The walls are basically panneling. ( about 1/8 inch). The studs are 2" or a little less.
Personally anything much over 1" is too long. I usually use stickons but have used anchors designed for panneling.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 08-15-2020, 07:29 PM   #4
Thanks, boss. I like the idea of sticking rather than screwing, too.
Old 08-15-2020, 09:24 PM   #5
Retired
MainelyUS's Avatar
We use Command Strips you can buy them for different size/weight pictures.
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
