02-08-2021, 05:32 PM
#21
Winterizing in North Texas
The forecast I see for low temps is:
Wednesday - 30º
Thursday - 21º
Friday - 19º
Saturday - 12º
Sunday - 16º
Monday - 16º
Tuesday - 25º
Wednesday - 27º
Brrrrrrrr
#22
I live in Canada's banana belt and just for piece of mind blow out all lines followed by a few litres of plumbing antifreeze. Once I see pink coming out of every faucet, shower and toilette I can sleep at night and not worry about what is going on out in my trailer during the winter months. I have noticed that after blowing the lines I see a lot of clear water that appears before the pink arrives. Low point drains even let some clear drop before the antifreeze shows up. I think it is cheap insurance.
Ken & Marilyn Holmes
Elora, Ontario
Canada
2012 FR Wildcat 313 5er
2016 RAM 2500 6.4 Hemi
02-09-2021, 01:21 PM
#23
Canada has a banana belt? What kind of bananas? They must be very tough bananas.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
02-09-2021, 01:23 PM
#24
Wednesday - 30º
Thursday - 21º
Friday - 19º
Saturday - 12º
Sunday - 16º
Monday - 16º
Tuesday - 25º
Wednesday - 27º
Brrrrrrrr
12 degrees F is a killer. Those who don't winterize will regret.
Jim & Renee
02-09-2021, 02:02 PM
#25
Scoundrel
Here's the surface temperature forecast for Monday morning, February 15. The temp/color scale is at the bottom of the image. Lots of record breaking low temps in Texas early next week....
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
02-10-2021, 10:38 PM
#26
You see the dead center of that bullseye?
I live THERE. [emoji3063][emoji24]
TT: Wolf Pup 16BHS-Black Label
TV: 2020 Traverse V92 Tow Package
WDH: Equal-i-zer 600/6000
Brake Controller: Curt Echo
02-10-2021, 11:43 PM
#27
Winterize? YES
They have changed the forecast and it's now supposed to get down to FIVE DEGREES by Monday. ANY water left in the lines, ptraps, etc. will freeze and there may not be enough expansion room to prevent damage.
This is not a normal weather pattern for Texas. Last time we had a cold front with temperatures this low... for this long... plumbers were kept busy for months. An rv needs to be winterized in this weather.
2015 Dynamax REV 24TB class C
02-11-2021, 01:54 AM
#28
Scoundrel
I have family in Ames. Unfortunately the arctic cold airmass will remain over Iowa at least through the early part of next week. Most unusual.
02-11-2021, 10:19 AM
#29
Originally Posted by CivEngPE
It's supposed to go below freezing this Friday and not get above until Tuesday afternoon. The low Saturday night is 12 deg, Sunday 18 deg, and Monday 20 deg.
YEP! I went ahead and winterized it with some antifreeze, drained the water heater, should be fine...
02-11-2021, 10:20 AM
#30
BURRR!! I went ahead and put antifreeze in the lines, drained the water heater, etc.
02-11-2021, 10:29 AM
#31
Insert witty title here
Just winterize it. $10 in RV antifreeze and 20 minutes of your time is is well worth it to prevent any potential problems and give you peace of mind.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
02-15-2021, 07:56 PM
#32
Have consider space heaters in your basement/storage tank area and leaving quarters for very cold day/nights.
02-15-2021, 09:26 PM
#33
A friend of mine in OK city OK had a water line freeze today. He has never had it freeze before, and it has been plenty cold there at times. If it hasn't been winterized yet, Good luck.
02-15-2021, 09:43 PM
#34
Originally Posted by PaulTRodneyG
We have a new 2021 Flagstaff EPro and this week it's supposed to get into the low 20's, but if there is no water anywhere in the system, what is the point of putting antifreeze in the lines? If there is any water at all, it would be minimal and wouldn't the lines expand enough to handle any freezing fluid? I just question why the bother of putting antifreeze in if it's not completely necessary?
Thanks,
Paul
I always winterize no matter where I stay. It only takes one time for some left over water in a joint to crack the joint. You may not know for a while, days, months, years but then all of a sudden you have a leak. The leak will start while under pressure and you can run gallons from your water hook up until you discover the problem and turn off the water. I had a person next to me on a nice day and while he was out that day his pipe started leaking and made a mess for him to clean up, going into the under carriage, cutting out floors to find and fix the problem. Anything below 32F and this can happen. I never take the chance. It is too easy to winterize and be safe.
02-15-2021, 09:51 PM
#35
Too late
I'm afraid I blew it. Just returned from a 22day journey and was going to go again in March. I live in Austin and didn't expect this weather. I have a little 1000 watt heater in my 32ft Lexington and turned on my arctic heaters. I turned on the water and nothing came out. I'm going to have a problem next week when this is over? I'm a newbie and of course I get the worst storm ever. Where should I look for leaks next week?
02-15-2021, 10:04 PM
#36
You might be able to save it if you get heat going in time. It usually takes a hard freeze to crack a fitting, and the PEX tubing can take some stress from expansion. Crank up the furnace, uncork the low point drains and open the faucets. Use a heat gun on the low points to free them up. propane is much cheaper than replacing a bunch of material.
02-15-2021, 10:07 PM
#37
Thank you, ill go ck it out now!
02-15-2021, 10:09 PM
#38
Sorry for your problem but, maybe you will be ok. Keep the heat on, open cabinet doors in the unit, hang a drop light, with a 75 watt bulb to add heat, in the water closet outside area and wait. DO NOT turn on the water until there has been sufficient time to thaw, leave an ice cube in a bowl in the sink and wait for it to melt then try the water. Open all taps and turn on the water from the outside slowly, not full pressure. A couple pounds of pressure will give you trickles in your sinks and then slowly check all faucets. You can also look for links for winter camping. These sites will have ideas on how to keep your coach working in freezing temperatures. You will not know if anything is broken or cracked until it leaks. With all the water back on and the faucets closed wait and listen to hear if you have any water running and go find out where it is. You can survive this without a problem, I wish you success.
02-15-2021, 10:12 PM
#39
Oh, are you sure it is not just the outside supply hose that is frozen? I had this happen years ago in Ft Worth, my coach was fine.
02-15-2021, 10:21 PM
#40
I dont know what else I can do at this point, its been freezing over 24hours, the water in the toilet wasn't frozen. I guess cross my fingers and hope! Thx for help
