Old 08-15-2021, 10:35 AM   #1
Shower mizer
Hope this post helps others with water pump issues. Leaving the campground my wife informed me that the water pump was not pressurizing the lines. I spent 2 hours trying to get the pump to pressurize the lines, but nothing was working. Then I remembered a post I read concerning the water mizer somehow interfering with the water pump. I checked the valve in the shower and sure enough it was partially open. I closed the shower mizer valve and the water pump immediately pressurized the lines. Hope this helps somebody that finds themselves in a similar situation.
woolfski is offline   Reply With Quote
Old 08-16-2021, 07:05 AM   #2
SeaDog's Avatar
Thanks for the info the shower mizer or water mizer has been the cause of many problems like yours and others having their FW tank fill when on city water.
Retired Navy
2016 Flagstaff 26 FKWS
Old 08-16-2021, 08:18 AM   #3
NMWildcat's Avatar
I don't agree that it is the Shower Miser that causes problems. It is the lack of knowledge and understanding of the system by the owners that causes the problems. It is a valve like any other valve that if not used correctly will cause undesired effects. Like not using WH bypass valves correctly, or outside shower valves being left on.
Here is the website for more information https://aquaviewinc.com/rv/
Plus there many youtube instructional videos out there.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 08-16-2021, 10:53 AM   #4
SeaDog's Avatar
You are correct most problems are user caused regardless the topic, my reply was not intended to tell the OP they were the problem but rather to thank him for the info.
Retired Navy
show, shower
