I guess I'm having a hard time deciphering your comments?
Let me try to understand... your front stabilizers didn't work and then you changed the switch and now none of the stabilizers work? (front AND rear?)
Does the switch control both of the front stabilizers together and another switch control the rear stabilizers together or do you have an individual switch at all four corners?
Which switch did you change?
Have you checked for voltage with a multimeter?
