Originally Posted by testersbc
i mean how to get the marker light out. looks like it just pulls out. bulb may need replaced. since it is 12 volt shouldn't be hard to replace.
The marker light housing is screwed into the rig with self tapping screws. If your lights are the Optronics MCL32 LED Series the lens can be gently popped off with a small screwdriver. The MCL32 lights are equipped with C.O.B. LED's, meaning Chips-On-Board. If the diode(s) are burnt out the light fixture has to be replaced. If you have the MC32 Series (incandescent), the lens come off the same way. These use a #194 bulb.
