Old 06-01-2020, 07:21 AM   #1
Tv mount
I have a 2017 Flagstaff 26RLWS what is the best way to install a tv mount. It seams there is only one stud to mount it to!! Any works of advice? Thank you in advance!!
Alan Carvel is offline   Reply With Quote
Old 06-01-2020, 12:11 PM   #2
Depends on where you want the tv.
We had a small trailer and no where to put it on the walls. So we put a locking swivel mount on the side of a kitchen cabinet.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 06-01-2020, 08:25 PM   #3
Now a "Top Member"
EdJunior's Avatar
I did a similar install, only I used a bedroom cabinet. I actually used the inside, so the cabinet is not useable for much in the way of storage, but we were not using it anyway.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 06-01-2020, 09:05 PM   #4
CincyGus's Avatar
You have a couple options when you only have one stud handy.
The easiest is to use a mount similar to this one that mounts on a single stud vertically.
https://www.monoprice.com/product?p_id=15867
I used this one for both a 22" in the bedroom and a 40" in the living area.
Another option I have seen is if there are a couple of studs which you can mount a finished piece of lumber like 1" x 6" by whatever length you need and then you mount the TV mount on that. Generally your going into a 1" think piece of stud with a 1/16" or 1/8" piece of luan so you can't use more than 1.25" screws unless your mount is thick or you go through the other side of the wall.
Plenty strong of you get good bites with your install screws. I did put a bungee on it when traveling to keep it from extending and putting enough leverage on the mount to pull the screws loose.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 06-01-2020, 09:26 PM   #5
Thanks to all!! I thought I would the mount like the one on the outside!!
Alan Carvel
Old 06-16-2020, 07:43 AM   #6
TV Mount
Since this subject came up, I have a question. Hope you all don't mind. We recently bought a 2019 Flagstaff 5th wheel. It came with a TV mount on the outside. We can't seem to find a TV mount for our TV that will fit this mount. We have looked at a lot of TV mounts. The one on the trailer has a round hole that looks like the opposing part should have a disk to slip down into it. Anyone else have anything like that? Thx
Leslie Lindell is offline   Reply With Quote
Old 06-16-2020, 07:50 AM   #7
Found on Amazon
I also have a Flagstaff and found the tv mount on Amazon. Please see attachment.
Old 06-16-2020, 12:32 PM   #8
bikendan's Avatar
Pics of the mount would be more helpful than a description.
Equalizer WDH
Old 06-17-2020, 08:46 AM   #9
TV Mount
It's actually the one in the previous reply. I then found them on Amazon. Thanks for the help everyone.
mount, tv mount
