Old 07-06-2021, 11:44 AM   #1
WaterPur Water Treatment System
Hi all,
We bought our 2019 used 5th wheel Flagstaff Super Lite 529BH 1 year ago, May 2020. The guy we bought it from bought it new in May of 2019.
He showed us the new filter and said it would be a bear to install so he didn't. I don't know if it came with one installed from the factory or not. The camper was still winterized we learned after we got it home. No water in the water heater.
Anyone know where it is or goes on the camper? FAQ sheet that came with camper says "water filter & water pump are most often located behind an access panel inside an outside storage compartment. Or 3 hinged cabinet door inside where city water & anti freeze port exit the trailer." Hmmmm, I can't locate it.
Any help would be appreciated.
Thx
Flagstaff 5th Wheel 529BH 36'
Ram 3500, dually, cummins
lannieoakley is offline   Reply With Quote
Old 07-06-2021, 02:08 PM   #2
I found it!! Holy Moly, it's behind the front pass thru. Just happened to be looking up and saw the top of the filter cannister over the partition.
Hopefully this can help someone else. They sure don't give you much info. And there was not one in there.
water
