05-25-2021, 12:32 PM
#61
My two cents worth....I agree with Scott (NMWildcat), the 5500 foot thing seems primarily CYA on the manufacturers part. We've had power outages from time to time and it seems to function okay on the gas at our 8000 feet. I also agree with him that Dometic's 1350 seems to be poor choice when on a slide, especially in altitude.
When boondocking a two way refer is the obvious choice. But when plugged in all time (other than when going down the road), the two ways have too many liabilities. Besides warning about operating them on gas above 5500 feet....and filling them too full.....and leaving the door open too long....they should also mention that you may have to add additional fans....and not to let the sun hit them.....and to avoid high temps....and prefer soft ice cream.
05-25-2021, 02:10 PM
#62
We don't have any issues with keeping it cold but only got this rig in October so we'll see how the summer goes. We just have issues keeping it running at altitude.We camped near the Superstitions in AZ in Feb and had no issues at all. But we were only at 2000 feet.
The Dometics in our previous (older) rigs had no problems. If this is an "upgrade" then Dometic got it terribly wrong. Here in the west there are LOTS of people like us who boondock at altitude. We have talked to the very nice service folks at our dealer and they have told us that many of their customers are calling and coming in with the same issue.
It appears we have a few choices: 1) live with it going off day or night then restarting it 2) void our warranty by trying the fixes suggested 3) replace with a frig that doesn't have altitude problems (pricey and do they exist?) 4) increase our solar power and run it on the inverter (also pricey) or . . . ? Please don't suggest a generator. That would be rude to all our fellow campers in the woods and irritating to us.
2021 Rockwood Roo 23IKSS "The Roadrunner"
2019 Ford F150 4X4 Ecco Boost with Max Tow Pkg
Two retirees & Benji the lover cat
Boondockers since 1982
05-25-2021, 02:37 PM
#63
Dometic1350
At the beginning we had a problem with frig not cooling properly. Found the flap between the doors was jammed and not seali properly. Adjusted the flap and everything works as it should.
05-26-2021, 03:52 AM
#64
Interior battery power fans for Refrig
We bought one of the D cell powered fridge fans about 3 years ago for our 1996 camper fridge. Made a significant difference in cooling. The batteries lasted through a 2 month trip to Alaska from Texas in weather from 100 degrees to 30 degrees. Worth the price. They still sell at most RV parts stores.
Air Force retiree. Live in San Antonio. 2006 Flagstaff 5th wheel, 1995 Lance camper, 2002 Chevy 2500 SD pickup. AZ State Park volunteer.
05-26-2021, 07:58 AM
#65
Originally Posted by 5picker
Sounds like you have the RM-1350.
That's what we have too and we really like it. (after some mods)
You are probably referring to the Automatic Cooling Cycling System that helps defrost the refrigerator. From the owners manual...
Automatic cooling unit cycling
system and Low ambient control
The refrigerator has been design with an automatic cooling
unit cycling system that helps reduce frost build up in the fresh
food compartment. The first automatic frost reduction cooling
unit cycle begins 60 hours after turning “on” the refrigerator
(for best operational results the refrigerator should be turned on
anytime between 4 and 10 PM), and will last for approximately
120 minutes. Thereafter, the cycle will automatically repeat
every 48 hours as long as the refrigerator continues to run.
The automatic Low Ambient Control (LAC) ensures troublefree
operation in low ambient temperatures (e.g below 50° F).
Same fridge.
Here is a snip-it from my sensor inside my fridge showing that cycle. Although it happens every 24 hours...
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
05-26-2021, 08:29 AM
#66
After replacing the cooling unit on this fridge I made some much needed mods.
This fridge in a slide out, bad idea and poor install from FR needed to be changed.
Directing the airflow up and out was huge!
Added 2 electric fans on a thermostat, sucking in below and blowing out at the top. Also a fan inside the fridge.
Seasonal
05-26-2021, 01:49 PM
#67
Platokidd....looks like you had your 1350 set up to do its thing starting around 2AM and it ran until 4AM, getting things up to nearly 40 degrees before it was done. Ans it does this every morning?
05-26-2021, 02:12 PM
#68
Hate RV Fridge
I have the opposite problem, even on a setting of 1, it freezes everything
05-26-2021, 03:40 PM
#69
RM-1350?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
06-01-2021, 05:58 PM
#70
Well... guess its making a liar out of me now. It was every day for a few days in a row. Mostly hitting 38 deg's during cycle. I need to spend more time looking into the the data.
Loading the fridge up does spike the temps upward and above 40.
I'm not at the camper today. My fridge is on the highest setting. Attached is my inside the camper temp and beer temp. I'm pleased and would call this normal.
Temps inside my camper can run 10 to 15 degrees warmer than outside. My campsite is mostly shaded.
Seasonal
06-01-2021, 06:01 PM
#71
Have you checked the thermistor?
Seasonal
06-01-2021, 06:28 PM
#72
With a very similar setup only with rooftop vent I started my fridge at 8AM this morning. By 10 AM freezer was at 0 and fridge at 40. Temp when starting in both compartments was 65.
Biggest issue is opening doors. Inside fans help cool back down in short order.
06-02-2021, 08:10 PM
#73
Originally Posted by Iowa Frogfarmer
Here is what Dometic says from the RM-1350 Operators Manual, page 11
My Source manual
REVISION C
Form No. 3313352.019 12/17
(French 3313353.017_C)
©2017 Dometic Corporation
LaGrange, IN 46761
This warning does not appear in a the prior release of the operators manual dated 2011. It does appear in the manual for my Dometic RM2351 revision D dated 2017.
That is a stupid statement. I’ve operated Dometic gas fridges above 5,000 ft for 50 years with no issues.
06-17-2021, 02:40 PM
#74
Our Dometic RM-1350SL continues to deteriorate. Used our newly purchased fan for the interior (battery operated) with no improvement. So the wife called Dometic and after a two hour wait talked with someone that went by the name of 'Wayne'.
Of course his response was that there was absolutely nothing wrong the the RM-1350SL......it was not installed correctly by Flagstaff (Forest River). We (the wife & I) expected the call to Dometic to be a waste but just wanted to hear their excuse....I mean opinion. Wayne did say that installing this RM-1350SL on a slide was a terrible idea.....and yet the manufacturers continue to do so. Lucky us. Our three year old Dometic appears to be dying, leaving us with an RV we can't use and more than likely a huge repair bill.
06-17-2021, 03:01 PM
#75
He's right. Natural convection of the air over evaporator and condenser coils is impeded by the angle of the vent at the top.
The only solution is to install vent fans either at the top vent to suck air though this area, or install fans at the bottom air inlet to blow air into the vent "chimney". A battery fan inside the refrigerator only helps when the refrigerator absorption unit is working properly.
Take a look at the titan refrigerator fans here and the install pictures.
https://www.amazon.com/Ventilation-C.../dp/B077TJCL3F
They should solve the issue an absorption refrigerator installed in a slide.
BTW, when running at full speed they only draw .5 amp so they are easy on the batteries.
06-17-2021, 03:03 PM
#76
Hey Dennis, you're a long way away but.... If you ever visit the Midwest, there is an Amish guy who specializes in RV refer repairs.
https://fixyourfridge.com
I had him replace mine 4 years ago.
There is a campground just north of him.
We spent the night at the CG and dropped my trailer off at his shop first thing in the morning. We drove into Shipshewana for some sightseeing and a great Amish hot breakfast.
My rebuilt fridge was ready at 1 pm. It was already getting cold when we picked it up.
I am a satisfied customer.
Maybe it's time to visit some Michigan state parks!
Peace!
Dan & Rita D
06-17-2021, 03:14 PM
#77
As others have said fans on the back side are a good idea. My new GD came with a fan and it is not even in a slide.
If I had to replace a LP/120V fridge I would try to find a 12v compressor fridge to replace it with. A little less cost and much better cooling.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
06-17-2021, 03:22 PM
#78
Flagstaff installed four of the little computerlike fans at the top vent that make a horrible sound when running.....which is ALL THE TIME!!!!!!!!!!
But I intend to try some fans at the lower vent as TitanMike suggests before I take my 10 guage shotgun to it.
06-17-2021, 03:34 PM
#79
The Titan fans are 120mm fans and when running full speed are really quiet. The kit comes with a controller that modulates fan speed according to temp in the vent stack. On mine the fans RARELY go faster than half speed and only hit max speed when the day is extremely hot.
I NEVER hear the fans running.
FWIW in my reading on this fan setup before I bought it appears they were designed specifically for absorption type refrigerators installed in situations where normal convection was severely restricted like in Vans and Slide installs.
06-17-2021, 04:00 PM
#80
I had the same problem
I had the same fridge mounted in slide - poor heat rejection. I added the internal recirculating fan which helps a lot when the fridge is pretty full. But the big difference was adding more fans to the outside (behind the unit). Below is a diagram and web-link - see the Side Vent Cutaway Drawing - this greatlyh improved performance
"We do not quit playing because we grow old. We grow old because we quit playing." ~ Oliver Wendell Holmes
Bill & Jo-Ann - Chesterfield,MO
2019 Vengeance 377V
2015 F-350
