Old 08-15-2021, 06:46 PM   #1
Weight epro
Hi All-
We just purchased a Flagstaff e-pro 19bh after researching the 2021 models. We ended up getting a 2022 but were surprised to see that the unloaded weight was 200 lbs higher than its seemingly identical predecessor. Anyone aware of what led to this 200lb increase? Our tow capacity is 4500, so every lb counts in our case!
Jennya is offline   Reply With Quote
Old 08-15-2021, 07:00 PM   #2
Backcountryboondocker's Avatar
How did you figure out that the 2022 weighs more than the 2021 model? Does it say on the factory specs that the 2022 weighs more now, or did you find this out by real world weights? (Physically weighing the TT on a scale)
Factory specs = approximate weights which can vary widely
Physical real world weights = Normally a shock (and a lot heavier) as to what you were expecting, and can be a few hundred pounds difference in factory specs
Backcountryboondocker is offline   Reply With Quote
Old 08-15-2021, 07:08 PM   #3
Thanks for the reply! We were just basing it on the factory specs for 2021 v 2022. From what you're saying, those can be quite variable. So perhaps the two would weigh the same on a scale and these were just estimates. Oh well! I was just curious.
Old 08-15-2021, 07:22 PM   #4
bikendan's Avatar
Originally Posted by Jennya View Post
Hi All-
Your bigger worry will be the loaded tongue weight..
If your max towing capacity is only 4500lbs, then your max hitch weight will probably be 450lbs.
Since that trailer has a fictional dry tongue weight of 425lbs, once you add the weights of batteries, factory options, water and trailer cargo, it'll easily exceed that 450lbs number.
You've focused in the wrong number. Don't feel bad because many owners of smaller tow vehicles have been sucked in by the clever marketing of these larger single axle trailers.
https://forestriverinc.com/rvs/trave...pro/E19BH/4362
Old 08-16-2021, 11:59 AM   #5
I have a GeoPro 19BH. With two full propane bottles and (2) 6V Golf Cart Batteries, my tongue weight with the trailer loaded is around 515 lbs. This is without anything in the water tank however.
Trailer:
2021 GeoPro 19BH / 190W Solar w/ (2) 6V Batteries
Tow Vehicle:
2021 Ford F-150 / 11,600 towing / 1826 payload
Casademike is offline   Reply With Quote
Old 08-16-2021, 03:25 PM   #6
bikendan's Avatar
Which is probably over the OP's 450lbs max hitch weight.
Old 08-17-2021, 04:08 PM   #7
When you get your trailer loaded, everything for a trip, your going to be in the 4000 to 4200 range. On my 19FD, we were 3800 including with 525 on the hitch. I have a single lithium battery, with lead battery, the hitch weight will be higher. You will need a weight distribution hitch, your tow vehicle will have separate specs with using a WDH. Lots of people are towing with vehicles with 4500 or 5000 tow vehicle capacities. Made sure when you do you first shake down trip, do it at a distinction that requires a few hour drive. It was on our shakedown trip, that convinced me I needed a WDH....
It’s also important where your towing, towing from NC to FL, is a lot different than towing from Denver to Leadville CO, or anywhere in the Rockies...
Enjoy your new trailer !
Kean M
2019 F150 Extended Cab, STX, 2.7l, 4WD
2021 Flagstaff E-Pro 19 FD
mcbridek is offline   Reply With Quote
weight
