19 rockwood 5th 2781ws Tv Antenna
any one know what antenna Rock wood uses, searched the net, no luck. Worked when i picked up the unit at dealer, got home 5-20 and parked at house tried it while cleaned packing, no signal. took it camping with the grand kids closer to where should be able to have TV no signal? climbed up top today, it's GONE! only the plastic base? covered it with a zip lock and tie wraps as can feel cold air coming out the hole maybe the cable went through.? Going to try and get warrantied, as im sure i did not knock it off. Lost a front LED docking light cover on the way home from picking it up also. if too much pain as any dealer is over 100 miles away, will replace it my self. Any help on brand? Any one else had this on a brand new rig? Thanks
