Originally Posted by smokinwrench
Bought our 8291 early this spring. It was a carry over unit, were first owners. Front A/C has been running rough, I got on roof to investigate it. The roof is bubbling and has wrinkles. About 2 inches on right side is lose entire length of camper. Is this normal for this new of a camper? Is this a warranty issue? Attachment 147244
Attachment 147247
It is a warranty issue but lately FR often deny it. The roof appears to be FR,s version of fiberglass but not the same as fibers and gelcoat. This stuff tends to migrate into corners and then crack. When it's installed they may skimp on glue an result with the "bunching" you have. That is not acceptable as it may well fail. Trouble is you may not know until water is in your ceiling and walls.
Too bad cause this roof is superior to rubber roofs, just not as is.
