Old 09-22-2021, 01:03 PM   #501
Hey, Tundra!
Why did you decide to replace the tongue jack?
What convinced you to go with a Husky 4500?
Thanks!
Witness_Protection is offline   Reply With Quote
Old 10-30-2021, 12:37 PM   #502
Originally Posted by Witness_Protection View Post
Hey, Tundra!
Thanks!
Really just by reading the reviews on it.
If I had to buy a new jack today it would be the exact same one.
It's quiet, fast, has auto stop, and powerful.
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2022 Ford F-350 Lariat, 4x4, CC, SRW, 7.3L
01tundra is offline   Reply With Quote
Old 10-30-2021, 12:46 PM   #503
Did a small mod to make a place to keep our fly rods while at the camp site.
Found some aluminum clamps on Amazon for 1" tubing meant for mounting LED light bars. Also picked up plastic fishing rod clips.
2019S Mod Thread
Old 10-30-2021, 06:30 PM   #504
JimM2109S's Avatar
You must be boondocking. That’d be a nice temporary storage location if you are.
Nice fly rods combos like yours, any fishing rod combo for that matter, would grow legs fast in a lot of places.
2022 MiniLite 2109s
2018 F-150 XLT 4x4, 3.5L, Max tow pkg
2019 Ranger Lariat 4x4 (in reserve)
(We're just getting started!)
JimM2109S is offline   Reply With Quote
Old 11-01-2021, 10:00 AM   #505
They'll only be stored there when we're at our campsite, and I don't have a problem breaking legs
2019S Mod Thread
Old 03-07-2022, 03:25 PM   #506
Decided to go ahead and tack weld the Anderson No-Sway brackets to the frame since we'll be keeping this trailer for the long haul. This will eliminated any chance of the brackets moving.
2019S Mod Thread
Old 03-07-2022, 03:37 PM   #507
Also decided to change out our digital Coleman thermostat for a MicroAir Easy-Touch smart t-stat. It wasn't inexpensive, but it sure is nice to not have to get up and stumble around in the dark with a flashlight when I want to change the setting.
Not sure why the picture makes the display look orange, but it's red while in heat mode and blue when in cooling.
2019S Mod Thread
Old 03-07-2022, 05:32 PM   #508
What is the model number of the Thermostat?
Also looking back I do not remember seeing the link to the MaxAir II's that you bought. Do you have that as well?
TIA
2020 Forest River Flagstaff Micro Lite 21FBRS
2018 RAM 1500 4x4 Laramie EcoDeisel
rrosson67 is offline   Reply With Quote
Old 03-07-2022, 05:45 PM   #509
TIA
Thermostat - ASY-352-X01
https://www.hutchmountain.com/produc...37335045472405
Vent Covers - Maxxair 00-933073 MaxxAir II Smoke Vent Cover. I bought mine from Amazon, but they're currently not available. I believe they do have the black covers, just not the smoke color.
2019S Mod Thread
Old 03-22-2022, 12:05 PM   #510
Hey, Tundra!
I looked through your posts but I didn't see where you modified the fresh water tank drain valve. I would like to install something besides the 1/4" factory drain and I understand that the newer 2109s have a 1" gate valve.
Have you replaced the factory fresh water drain valve? If so, do you have any pictures?
Thanks!
Old 03-22-2022, 12:18 PM   #511
Hey, Tundra!
Thanks!
Our 2020 came with the large drain valve (think this was the first year for it).
2019S Mod Thread
Old 03-23-2022, 02:47 PM   #512
Replacing 1/4 Fresh Tank Drain Valve
Has anyone else replaced the small fresh tank drain valve with the larger gate-type drain valve?
As Tundra mentioned, 2020 and forward Rockwoods come from the factory with what appears to be about a 1" gate valve for draining the fresh water tank.
Thanks!
Old 03-23-2022, 02:52 PM   #513
Thanks!
Unless the threaded outlet in the tank is larger, the only way I could see this happening is if you used a plastic welder and installed a larger outlet.
2019S Mod Thread
Old 03-25-2022, 05:19 PM   #514
I’ve been wanting to rewire our awning for a couple years now because I’ve always believed that it was slow due to inadequate factory wire sizing and voltage drop.
Well today was the day, it was to the point that I would pull on the awning arm as I was retracting it to help it come in and all the interior lights would dim even while hooked to shore power. Not anymore! This thing flat out moves now and no more lights are dimming. I’ve never heard the motor sound like it does now.
Used a forward-reverse relay module to control the awning. I ran 8 AWG +/- wire over to the relay to power the motor. Ran the 12V+ through a 25A Blue Sea breaker.
On the factory switch all I had to do was simply remove the ground wire from it (the green/white wires), that allows to switch to send 12V+ to the relay coils in each position.
https://www.amazon.com/dp/B08DKDSSB9...roduct_details
2019S Mod Thread
Old 03-26-2022, 10:10 PM   #515
uno676's Avatar
Just finished sealing the roof with EternaBond tape.
Took two days to complete.
Hows this holding up? and what size of tape did you use?
Thanks,
Lonnie
2020 Rockwood 2509S
2018 Tundra DC Limited
uno676 is offline   Reply With Quote
Old 03-27-2022, 01:32 PM   #516
Thanks,
Lonnie
Still doing great.
2" down the sides and across the back.
4" everywhere else.
2019S Mod Thread
Old 03-27-2022, 02:08 PM   #517
uno676's Avatar
Thanks you
You have a great thread here
2020 Rockwood 2509S
Old 03-27-2022, 07:58 PM   #518
uno676's Avatar
Bug you one more time what are the Stabilizers you put on your camper,
2020 Rockwood 2509S
Old 03-27-2022, 08:03 PM   #519
30” Stromberg Carlson
Old 03-27-2022, 08:17 PM   #520
This sounds interesting but I'm having trouble grasping the circuit despite the pictures. Can you summarize with a schematic?
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
210, 2109s, lite, mini lite
