It is annoying to try to pull the valve on the front grey tank with the front slide out. I've used a "Y" connect to get all 3 tanks hooked up to sewer, but that brought up another problem. If I left the front valve open, then dumping the rear black tank caused some of that effluent to intrude into the open front grey hose. Since that front tank was left open, flushing it wasn't easy. So here's my plan for my next trip. I'm adding a dump valve between the front grey hose and the "Y" connection at the sewer. That way I can leave the factory front tank valve open, and control the outflow at the sewer end. I can dump the black, followed by the rear grey, then use the black tank hose flushing inlet, and not have anything go into the front grey hose.
Here's the new valve on Amazon: Camco Ready to Use Gate Valve with Built-in Clear Adapter | Fits All 3-inch Sewer Fittings | Ready to Use Construction (39053), $25
