Old 02-19-2021, 06:22 PM   #81
Originally Posted by prairieflatlander View Post
Question for you. How did you mount your antenna's for the WeBoost RV Cellbooster? Did you go the more permanent route? Looking into one as well. Have the same trailer.
Here is what we did: The outside antennae bracket connects to the ladder, cable goes from antenna into the exterior RV satellite connection. Inside behind the tv, another short cable runs from the satellite connection have into the booster. Booster mounted on wall behind tv and is connected to the 12volt system via the stereo. The indoor antenna sits on counter under tv. Cord is several feet long, can be moved around somewhat & even reaches out the door if we are sitting outside. Feel free to ask for more details as we did have to get certain connectors to make it work if you need!!
Gottaluvlife is offline   Reply With Quote
Old 02-19-2021, 06:36 PM   #82
Awesome! I think that makes sense. In the past with my old trailer i tried connecting through the satelite and it wouldn't work. Happy to hear that it works with the 2608.
prairieflatlander is offline   Reply With Quote
light, rockwood
