2104S uses a Lippert through frame system and has manual crank option. The opening is on the curb side by the axles.
Jack has a separate crank but can take a regular ratchet/socket with extension from what I understand.
The slide lock is not needed unless you have slide rack failure and the slide won't stay in. You can use any "truck bed adjustable cargo bar" as that is all the factory lock bar is, but cheaper
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
