Old 05-04-2018, 11:42 PM   #1
2109s Instrument panel light
When it's dark outside & we need to check the Instrument Panel - it is impossible to see.
Forest River, it would be lovely if in future models you put a little spotlight or even a ceiling led light just above this panel. It would also help to have light for the pantry.
We put a stick-up battery light to solve this problem, but it's not quite 'sticky' enough to stay up.
(Anyone else frustrated with this dark spot? How did you solve it?)
2019 MiniLite 2511s
2014 RAM 1500 5.7L
Abcall is offline   Reply With Quote
Old 05-05-2018, 09:24 PM   #2
I had the same problem...
I used Command strips to attach a battery LED light above the panel.
2018 Rockwood 2109S
Cleveland, Mississippi
Sahall is offline   Reply With Quote
Old 05-09-2018, 01:12 PM   #3
Had the same problem. Used a reading light that's used for clipping on a book with a flexible arm. Clipped above the door and adjusted it so it shines on the panel.
Timbuktu is offline   Reply With Quote
210, 2109s, light
