Well, I didn't find any capped wires behind the inside cover. I found two wires that appeared to run to the two speakers. The third wire, which looped through the opening, seemed to run between the two lights. These two lights are connected to a wall switch, so I assume there's a wire from the switch to the first light, then this wire continues to the second light. This won't work for a fan, since the light must be switched on for there to be power in the wire. The lights do not have individual switches on them. I need to do a more rigorous examination of the opening to see if there's a wire tucked back out of sight.
Ken
2018 Rockwood 2706WS
2007 Ford F-350
