Originally Posted by chriscowles
I don't have two tanks but, for those who do, are there separate drain connections? Or do all tanks drain to a single connection for the dump station? The latter seems most likely.
Originally Posted by Mr. Dan
My trailer has 2 gray tanks and one black. There is a unique dump valve for each of the 3 tanks. There is only one dump outlet which handles all three tanks.
Not all are like this. When we were shopping for our Mini Lite, I saw some with a gray and black that both go to one dump outlet, and then a 2nd gray that has it's own outlet. The specific one I saw had a slide stuck out in between; I knew it wasn't something I was going to like. And since one outlet was in front of the axles and the other one was behind the axles, I didn't see that they could be hard-piped together very well.
So you need to understand exactly what you are getting or have.
2011 Traverse LT, 3.6L, FWD
