Loaded up I'm guessing about 1200 lbs +, but still just a guess. I Cat scaled and got gross weight of 15,700 with an unloaded 7000 lb. truck only weight.
Truck scale was busy. Didn't get chance to get another weigh in..
You need your tv rear axle weight when you weighed it. You can reweigh your truck empty to get the rear axle weight. Or you can see if it’s published somewhere. Then subtract the two
Thanks, the truck bed was loaded with a couple hundred lbs. of stuff. Plus
100 lbs of WD hitch. I just need to get back and finish weighing it. No problem with the rig. Just curious if anyone had an actual scale weight. A lot depends too, on trailer load at the time..
