Old 02-21-2013, 01:26 PM   #1
Senior Moment
rockport's Avatar
7 pin plug location.
Ok I am installing a 7 pin connection in bed of truck. Planning on drivers side. What's better, towards cab or back by tailgate. Looking for insight from those who have one setup.
rockport is offline   Reply With Quote
Old 02-21-2013, 01:42 PM   #2
B47
Mine is on the Drivers side and just forward of the tailgate for the following reasons:
1. The hitch/unhitch handle and safety indicator pin on my hitch is on the drivers side.
2. I can plug in my cord more easier with the plug there plus the RV cord probably would not reach further forward and still have the necessary slack for turning.
3. I can communicate with my DW when unhitching and hitching as she is the driver during these operationswith me being on the drivers side.
Old 02-21-2013, 01:54 PM   #3
Same here-Installed on the drivers side back toward the tailgate. Be sure to check for double wall area.
Wilkrich is offline   Reply With Quote
Old 02-21-2013, 02:07 PM   #4
rattleNsmoke's Avatar
Driver's side/rear. The reason I say that is 'cause I can lean over the tailgate and connect\disconnect with ease. Use a hole saw. 1 1/8" if I remember correctly. Depending on the model of your TV, Ford has a stake pocket which is perfect. Just make sure the cord will bend enuff to make the 90 deg turn downward without fender interference.
rattleNsmoke is offline   Reply With Quote
Old 02-21-2013, 02:11 PM   #5
Senior Moment
rockport's Avatar
Thanks for all the input, looks like drivers side between wheel well and tailgate.
I'm off to get r done.. This forum is awesome..
Old 02-21-2013, 02:29 PM   #6
Owner/Operator
RodeoGeorge's Avatar
While I was installing mine, I put one up in the bed on the drivers side for the 5th wheel, and also one on a plate next to the Hitch Receiver for when I tow other conventional trailers. It's paid off, as I've pulled some trailers with the 7 Way connector that would not have reached the connector in the bed.
My opinion, do them both while you're doing the wiring.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-21-2013, 02:44 PM   #7
B47
RodeoGeorge
Probably a good idea - we never use our Ram 2500 for anything but towing our FW so any other uses are not a problem. Plus the TV has a factory installed connector in the rear bumper - so we are covered.
Old 02-21-2013, 02:48 PM   #8
phat phrog stunt crew
im just using the one thats installed by the receiver hitch. works for me and i dont have to cut/drill any more holes in the bed or fish wires thru.
dwaynerz is offline   Reply With Quote
Old 02-21-2013, 02:58 PM   #9
hotrodj125's Avatar
Yep, thats all I've everhad is the one under the bumper by the reciever hitch, but I am going to add the one up in the box by the left tailight.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 02-21-2013, 03:10 PM   #10
Senior Moment
rockport's Avatar
Already have factory installed at bumper. Just need to add the one in the bed. Unfortunately my 2" hole saw is to worn out to drill thru bed wall. Will pick one up in morning and install then.
Old 02-21-2013, 03:40 PM   #11
Ayup...that's what it was...a 2" er.
Old 02-22-2013, 12:33 PM   #12
Helmsey's Avatar
I put mine between the wheel wells and the front of the bed so I could attach it without having to squeeze myself between the camper and tailgate to reach it. The other reason is that Chevy has all the wiring for a bed plug bundled up under the front of the bed, and it would hot have reached behind the wheel well.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 02-22-2013, 01:21 PM   #13
Senior Moment
rockport's Avatar
Well it's done. Took a whole 10-15 min. Had 9 ft of cable and only needed about 4, since harness is at back of bed. Now just waiting on the tpms system.
Old 02-22-2013, 01:24 PM   #14
Now a "Top Member"
EdJunior's Avatar
Cool. Hope you got it high enough. I got mine too low and have to redo it.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 02-22-2013, 01:30 PM   #15
Senior Moment
rockport's Avatar
Put it about 1/4 way down from bed rail. Hopefully that will work , picking up 5th wheel in couple of weeks will know for sure then.
Old 02-22-2013, 01:30 PM   #16
Not-so-Junior Member
VenturaBill's Avatar
I liked the position on my 2005 F350 the best. Just forward of the hitch on drivers side. My 2012 F250 with the '5th wheel prep package" came with the 7-pin connector located farther back close to the tailgate.
While both positions work well, the forward position is safer since you're not reaching or sticking your head under the trailer to connect or disconnect the plug.
How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?
• 2012 F250 6.7L Lariat 4x4 long bed
• 2013 Columbus 295RL
• 1952 Blonde Nurse
VenturaBill is offline   Reply With Quote
Old 02-22-2013, 01:33 PM   #17
golfmedik's Avatar
Here is the location that I've used in both of my trucks. Works for me. You'll like the two locations.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 02-22-2013, 05:45 PM   #18
Now a "Top Member"
EdJunior's Avatar
Mine is just a couple of inches lower than that, but it is too low. My arms are just a tad too short.
Ed and Sharon
2010 Wildcat 28RKBS
Old 02-22-2013, 06:48 PM   #19
Here's where Ford is putting them with the factory "5th wheel prep package". I do like it but I prefer it in front of the fender-well so I don't have to be under the front of the trailer to connect...
• 1952 Blonde Nurse
Old 02-22-2013, 08:50 PM   #20
Now a "Top Member"
EdJunior's Avatar
Yeah, that's better VenturaBill. I like that. I'm going to move mine up that high, but I think forward about 6 to 8 inches.
Ed and Sharon
2010 Wildcat 28RKBS
