Old 06-14-2013, 11:56 AM   #1
8281 slide out
Good afternoon I was wondering if anyone else has had a problem with the slide out removing the window gaskets? If you have,how did you render the problem?
Hilltophunter is offline   Reply With Quote
Old 06-16-2013, 09:22 AM   #2
Anyone?
Old 06-16-2013, 02:53 PM   #3
Owner/Operator
RodeoGeorge's Avatar
I think you might not have gotten an answer because your question is vague.
What specifically do you mean by the Slide Out removing the window gasket?????
Could you provide more details, or a picture if necessary?
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-16-2013, 05:08 PM   #4
When the slide goes in or out, the gasket around the window gets caught on the seal as it goes by.
Old 06-16-2013, 05:18 PM   #5
Denver, CO
garbonz's Avatar
I can't envision what you mean. Is the window next to the slide or in the slide. i assume it is the slide side window, but what gasket would be exposed that would be caught.
picture is worth a thousand words
2017 Fuse 23T
Old 06-16-2013, 05:25 PM   #6
Its the window in the slide. Its the weather trim around window. Not my unit but the gasket around this window gets pulled out every time I close or open it. This is the first time I have encountered this.
Old 06-16-2013, 10:02 PM   #7
rbuilder's Avatar
I would try some silglyde from napa. it's in a plastic squeeze tube kinda like what toothpaste comes in. its a silicone grease that you can apply then wipe off the excess. it will leave a super slick film on the gasket. we used it in the hot rod shop I worked at, to keep the door gaskets from sticking to fresh paint and keeps the seals soft. hope this helps.
rbuilder is offline   Reply With Quote
Old 06-16-2013, 10:58 PM   #8
mstell2's Avatar
I have a 8281ss and do not have this problem, might want to check with dealer about this problem.
mstell2 is offline   Reply With Quote
Old 06-17-2013, 09:12 AM   #9
I also have this trailer, I would guess your slide is out of alignment. I have not had this issue, although I am now knocking on wood!
2013 Rockwood 8281SS
2006 GMC 1500HD 6.0L 4.10 GAS HOG!
Rochester, NY
rcnhoward is offline   Reply With Quote
Old 07-04-2013, 10:38 PM   #10
Thank you rbuilder. Your advice seems to have worked
