Old 03-27-2017, 05:29 AM   #1
hitch hiker's Avatar
8289ws wardrobe slide seals
has anyone had a problem with the side seals?
both of ours have split, unit was new in june 2016.
have checked all cables and they are straight and level and not catching anywhere.
bottom left and top right have split, gap on bottom left does seem smaller than other side, but i cant see that the gap can be adjusted.
any suggestions
ali and steve
rockwood signature ultra lite 8289ws 2016
dodge ram 2500 2005 5.9 turbo diesel
2013 - 168 days camped 2014 - 217 days camped
2015 - 210 days camped 2016 - 189 days camped
2017 - 198 days camped
hitch hiker is offline   Reply With Quote
Old 03-27-2017, 12:17 PM   #2
jtatum65's Avatar
Pictures would be helpful
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2019 Dodge Ram 2500 Big Horn 6.4L 8spd 4x4
Nights Camped 2019 = 40
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 03-27-2017, 12:23 PM   #3
tmfaulksr's Avatar
i have a 2015 8289ws diamond pkg so i am all ears.
I've not had the problem. i have used the slide seal lubricant
as an effort to keep them in great shape.
again I'm all ears..
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 03-27-2017, 02:43 PM   #4
Left Coast
OC ran a length of aluminum flat bar full length to reinforce...Click image for larger version
ID:	133056.....Not shown in my pic, as l will do when I get back home
Old 03-27-2017, 02:45 PM   #5
Left Coast
Have also seen where mid way out on slide, from top to bottom, another thin flat bar was added to make sure the seal flapped fully
Old 03-30-2017, 02:35 AM   #6
RangeMaggotBob's Avatar
Me, too. On everything you said.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 03-30-2017, 05:13 AM   #7
B and B's Avatar
any suggestions
ali and steve
I just traded my 2013 8289WS. My slides sealed fine. When you talk gaps is the has the actual slide moved inside the frame? Are the 3 rollers on the bottom working? This could cause slide misalignment.
Old 03-30-2017, 05:32 AM   #8
I have a 2015 8289ws and is in shop for a leak on the bottom right corner area of the wardrobe slide out. Have the repairs fix the problem for anyone's else? Also having a tow hitch installed.
carlismr is offline   Reply With Quote
Old 04-27-2017, 06:25 PM   #9
I have a 2015 8289ws and just got it back from the shop for the same issue with the wardrobe slide. The seals on both sides had split and you could not actually see it until you ran the slide part way out. Fortunately the extended warranty paid for the seal and labor, but not shipping. I personally think that the clearance between the slide and the slide opening is too narrow.
mrarmyaustin is offline   Reply With Quote
Old 04-27-2017, 07:09 PM   #10
Unforchantly my leak turned out to be the outside frame part of the slide out. Just needed Sealant around the frame . Simple fix.
Would you have pictures for future reference in case I have the same problem?
Thanks Mike C.
seal, slide
