Old 03-28-2013, 06:16 PM   #1
8293rkss bathroom issues
Ok, need help! we stored the camper after thanksgiving and are taking it out for the first time since then, we have water pressure everywhere EXCEPT in the toilet...any ideas or help would be appreciated!
Oubie Jr is offline   Reply With Quote
Old 03-28-2013, 07:04 PM   #2
Professional Texan
TexasBob's Avatar
I would guess a stopped up flush valve. I have had it happen to me. Sometimes you can remove them and "flush" them out, other times you just have to replace them..
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 03-28-2013, 07:14 PM   #3
So what's the easiest way to take that off?
Old 03-28-2013, 07:16 PM   #4
This?? Not sure if the pic will show up, but it tried!
Old 03-28-2013, 07:21 PM   #5
Professional Texan
TexasBob's Avatar
The eastest way is to pull the toilet.
Yours may be different but 1) disconnect water connection 2) take nuts off the two bolts holding it down.
Once you get it off there are a couple of screws and piece of linkage to take loose to remove the valve.
Texas Bob
Old 03-28-2013, 07:25 PM   #6
Thanks so much for the info! We may try it! ...or we may make do untill Sunday.... :/
Old 03-28-2013, 07:28 PM   #7
Professional Texan
TexasBob's Avatar
Be sure and pay attention to the way the valve comes off, maybe even shoot a picture or two. It will be valuable when you start to reinstall it.
Texas Bob
Old 03-28-2013, 07:35 PM   #8
Thanks for the heads up!!
Old 03-31-2013, 03:57 PM   #9
And this is what we found when we pulled the toilet this afternoon! Wow!
Old 03-31-2013, 04:22 PM   #10
TURBS's Avatar
This happens to facets as well.
Not uncommon.
Do u have a water filter?
Old 03-31-2013, 04:25 PM   #11
Well at least now I know what to look for! Super glad my DH is handy and its fixed and no trips to the "shop" woohoo!!
Old 03-31-2013, 04:26 PM   #12
There isn't a filter on the outside, but there is one under the lavatory....obviously not catching much....
Old 03-31-2013, 04:34 PM   #13
TURBS's Avatar
Most of that most likely was there during the manufacturing process.
Old 03-31-2013, 04:49 PM   #14
Well that's kinda crazy! We are going get a filter for outside if we can find one!
Old 03-31-2013, 06:42 PM   #15
Professional Texan
TexasBob's Avatar
That is a good thing. It's always good to do it yourself if possible, but sometimes its beyond your skill set. The trick is to know what you can do and when you need someone with more expertise.
Also when you do it your self you gain knowledge that will help you later.
Texas Bob
