Old 07-03-2018, 09:21 AM   #1
Question 8828WSA Lights in storage area
I have a 2018 8828WSA 5er. There are milky white ~4” diameter 3/8”-1/2” top to bottom, what look to be lights in the front and side pass through storage areas. They have 2 wires attached. For the life of me I can’t find a switch. Don’t have a pic to post and the 5er is a ways away. Are they lights? A switch? They do not come on when opening hatch doors. Seems like a silly question to ask
Camp20144 is offline   Reply With Quote
Old 07-03-2018, 09:24 AM   #2
csyrell's Avatar
Check to see if there is a button in the center of the disk. Press it. It's an on/off switch.
2018 Rockwood Mini Lite 2506S
2018 Rockwood Ultra Lite 2902WS
2013 F150 EcoBoost
csyrell is offline   Reply With Quote
Old 07-03-2018, 09:31 PM   #3
Hi csyrell,
The milky white cover is one smooth surface. No button in the middle or center of it. I thought that the entire light cover would push like those battery click lights you can get for poorly or unlit closets but it doesn’t push. The fixture is solid - glued to the base.
Old 07-03-2018, 09:44 PM   #4
csyrell's Avatar
It must be different on your signature than on my ultra. Did you check the control panel inside?
2013 F150 EcoBoost
Old 07-04-2018, 12:51 AM   #5
Yeah, tried control panel and every light switch(interior and exterior) I could find. I’ll run across it eventually. Probably located some place real obvious -
light, storage
