Originally Posted by robmcqueen
Perkd , how well does your 1500 tow your 2608
If you are buying a truck for your 2608BS, get a 3/4 ton. If you already have a half ton Silverado 1500, it will most likely pull the 2608BS, but as noted, you will probably experience more sway and more effort pulling.
That said, my 2020 Silverado 1500 pulls my 2608BS adequately. I have the 5.3L and 8-speed trans, not even the max tow package. It can be done. But the 2608BS is at the top end of the 1500's capacity.
