07-09-2021, 12:56 PM
Addition of 2nd AC unit
Hello all,
We have a 2021 2613BS and am considering adding a second AC in bedroom. It is already AC ready, my question is how much will it cost me to add one?
Also, if I have a 15k in main room, can I add a 13.5 in bedroom without harm?
07-09-2021, 05:52 PM
When we upgraded in December to the 2883ws the dealership stated that if we wanted the second AC in the bedroom (13.5K) it would be $1495.00.
07-09-2021, 05:55 PM
Does your camper have 50A or 30A power?
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-09-2021, 06:03 PM
The 2883ws is a 50 Amp service.
07-09-2021, 06:59 PM
It is 50 amp
07-10-2021, 10:25 AM
Just bought a 2883ws. Finding that one AC is not enough for the California heat. I saw some forums where the second AC unit has a separate 20 amp circuit and plug to shoreline. Anyone know if that is the case with the rockwoods?
07-10-2021, 01:34 PM
Originally Posted by Momboy
Hello all,
I cannot find it at the moment. But someone makes an even smaller unit that is extremely quite. Which is exactly what you want above your head in the bedroom. And you don t need a big unit in the bedroom. I think it was rated at around 1.1 or so.
Good Luck.
07-10-2021, 01:37 PM
if you have a 50 A power cable its pre wired w/its own breaker. I'm getting prices now, if ome is available due to covid
07-10-2021, 02:09 PM
I just added a 2nd to the front of my trailer recently. It's a Dometic Brisk Air II totaling approx $1270.00 w/install (approx 2hrs). It does a great job of cooling it down, but it's certainly not quiet however the noise helps me sleep at night while drowning outside noise at the same time.
2020 Wildcat 322RLI
- Pulled by a 2022 Silverado RST Crew Cab 1500 4WD
-- 6.2L/10-Speed Trans
07-10-2021, 03:29 PM
The cost of the second AC unit will depend on how much of the job, you are willing to do yourself. A new 13.5 or 15K unit purchased online will run around $700.00, your most difficult task will be getting it onto the roof. Electrical connection is simple, white wire to white, black wire to black and green wire to ground. I installed a second 15K in the bedroom of our 5th wheel, got a man with small crane on his work truck to live the unit onto the roof. The unit is held in place by four bolts that are installed from inside the trailer.
07-10-2021, 03:35 PM
You may be thinking about the new Truma AC. Very low profile and supposed to be super quiet
07-10-2021, 04:04 PM
I added a second ac to the bedroom. Main unit is the 15btu Dometic. The bedroom unit I choose is the Colman Mach 8, 13.5btu. Not too noisy and is lower profile than the Dometic low profile by quite a bit. Have to consider height with a full profile 5er. Very happy with the performance and sometimes run it on fan only at night.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
07-11-2021, 08:28 AM
I'm following this post as am interested in the same thing. Need low profile because of storage situation and looking for a quiet unit.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
07-11-2021, 08:36 AM
A 13.5 will run close to $800 and a 15k $900 right now online. And just be aware that if you buy online and install it yourself you might have issues getting warranty coverage on it if you have an issue.
07-11-2021, 08:53 AM
Will the additional air conditioner run off a separate thermostat or the existing control? Mere curiosity, I ain't adding one.
-- Chuck
2006 Roo 23SS behind a 2017 Ford Expedition
07-11-2021, 12:31 PM
Second one usually runs separately with it's own controls
07-29-2021, 02:44 PM
I installed my own 2nd AC. Hardest part was getting the darn thing on the roof.
2016 Windjammer 3025W Diamond Edition
2016 F350 CC LWB Lariat 6.7 PSD DRW 4x4
2 GSDs Ranger and Dusty
07-30-2021, 08:03 AM
I plan to use my tractor bucket to get it up there, so not too worried about that part. Handling it up there afterwards may be fun, as don't want to tear the roof membrane sliding it into position. My biggest fear is not getting it fully sealed. Is that part pretty straight forward? Does the unit come with a seal kit, or is that something to be purchased in addition to the unit?
2003 Duramax
2017 Crusader 315
07-30-2021, 09:21 AM
2nd AC installation
You do not want to slide the AC unit on the roof for two reasons, one, you may damage the roof and two, you may dislodge and damage the seal that is in place on the bottom of unit. It is best to have someone to help you lift it into place on the roof. I installed a 15K Dometic unit that came with the seal, I had to order the inside ceiling control and attaching hardware in addition to the unit that goes on the roof. Once you get the unit in place on the roof, the rest is a easy operation.
07-30-2021, 12:25 PM
I lifted mine above the trailer using a pully hanging from my rafters, my son held on to the rope, then backed the trailer up under it. Once I got it backed in just right spot I had my son lower to me and I only had to lift and move it a few inches to get it set. My Coleman came with a 1" seal already attached to the bottom. Once you get it centered over the hole and the inside plate, the bolts go in each corner. Mine had small red tabs in the corners that were a certain length, tighten the bolts down to compress the seal until the tabs touch the roof. Genius idea! I also went around it with self leveling caulking. Probably overkill and I may hate it if I ever have to remove the AC but didn't want the chance of any water leakage. Take your time cleaning up the old sealant from the vent, that membrane will stretch out of shape and can easily tear a hole . About 3 days planning and 6 hours later I had a second AC. Weight is about 90lbs
