09-07-2020, 02:06 PM
#761
How do I unmount the tv?
I have a 2013 Windjammer 3001w. Im wondering how to unmount the tv in the living room. Theres no room to reach behind the tv. People say lift it and should pop off, I tried it but not at full force, I dont wanna break anythinh. I wanna upgrade the tv. Has anyone done this?
09-07-2020, 02:21 PM
#762
You will need a 7/16 wrench and reach around the tv. there are 4 bolts where the mount connects to the tv. Just loosen them a couple of turns and the tv will lift off.
2020 Coachmen Chaparral 336 TSIK
2004 F350 Crew cab SRW 6 l Diesel
Bonnie the DW
Charlie, He doesn't know he is a dog
Peanut the cat
09-07-2020, 02:29 PM
#763
If your tv is mounted the same way as ours it will swivel out
We have upgraded our tv to a larger size. Hope you can figure it out.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
09-07-2020, 03:00 PM
#764
The 3001w mine is 2013 is in a recessed area . Slips up on 4 special screws .I hold bottom center of TV and tap up on bottom on each side of where I hold it just have to increase the force it will slip about 1/2 in or so then pull out to unplug. The 3001's don't swivel as it's behind the side of the slide with the slide in.
09-07-2020, 03:09 PM
#765
I know were the tv is on a 3001. I also have a 3001w and our tv pulls out and swivels. It is in a recess with 2 speakers set in the recess.
Terry and Janet
2007 Ford F150
09-07-2020, 03:21 PM
#766
Mine isn't on a swivel and my speakers are in the ceiling with a base in cabinet at floor. The back of the TV has4 special head screws that slip in slots on bracket mounted on wall.
Evidently your's is different , so we can't be sure what the original poster has sorry for the confusion.
09-07-2020, 03:37 PM
#767
Yours is the same as mine from what your describing. Theres no way I can get back there. My hand dont even fit back there. Im gonna try that. I also have the speakers on top.
09-07-2020, 03:50 PM
#768
To change the TV you may have to change the wall bracket the last TV I got for house bedroom the hole placement was different on the back of the set.
09-07-2020, 04:15 PM
#769
Thank you, Its being stubborn but i can see it lifting. Kinda hard, I dont know why they did this. They could have atleast had a swivel. Im gonna try later today when I come home from work
09-08-2020, 05:58 PM
#770
the 3001w mine is 2013 is in a recessed area . Slips up on 4 special screws .i hold bottom center of tv and tap up on bottom on each side of where i hold it just have to increase the force it will slip about 1/2 in or so then pull out to unplug. The 3001's don't swivel as it's behind the side of the slide with the slide in.
this worked! Thank you a bunch!! Really appreciate it!
11-13-2020, 08:45 PM
#771
MCTroy
Our Jammer turned 6 and started having some issues. Not unexpected since we have used this trailer a lot.
We need some advise on the 3 lights in the bedroom slide. Our bedroom is in the front. Lights may or may it work after the slide goes out. Giggle the wire under neither and they might work. This only applies to the lights in the actual slide. Anyone have any idea of how to find the ground wire? Where these wires start from? Or how to get a wiring schematics from Forest River?
Thanks!
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
11-14-2020, 12:37 AM
#772
If your is wired the same as my 3001 check inside the wire loom. Mine had a bad connection were the wire connected to the slide out. The crimp was not tight on the connector. Hope this helps.
Terry and Janet
2007 Ford F150
11-14-2020, 07:31 AM
#773
MCTroy
Caper, thank you. I hate to be ignorant, but is a wire loom like a connector? We followed the wiring in the black casing up to where it goes between the outside slide wall and skirting. Where was your wire loom? I appreciate all suggestions! I hate to.pay $120 for an hour to have our dealership fix something so simple.
2018 Ram 2500
Ohio River Rat
11-14-2020, 07:33 AM
#774
MCTroy
Update, Amazon is a good resource. So the wire loom is the black covering. We will remove that today and see what we find. Thanks again!
2018 Ram 2500
Ohio River Rat
11-14-2020, 12:57 PM
#775
MCTroy
Caoer- thanks! We took your advice and pulled the black wire loom apart. The loose ground wire was easy to find and fix. We are much relieved that it wasn't up into the slide.
2018 Ram 2500
Ohio River Rat
11-24-2020, 07:52 PM
#776
Was looking at some You Tube today, thinking I might see some clever mod I might try on our 3029W. Didn't find any. However, came across a video of a 3029V. Didn't know this even existed( Am I the only one ). Pretty clever. Make a few changes to the rear living area, and BOOM outdoor kitchen.
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
Remember those that died for us. And remember who killed them.
12-02-2020, 10:54 PM
#777
MCTroy
Well, wone too many tree branches hit the roof of our Windjammer. We need the rubber membrane replaced. Fortunately there doesn't appear to be any water damage as we have kept the under part dry. Duct tape has been our friend. Replacement cost for the rubber roof:$7200. We will pay our deductible only so we aren't crying too badly.
2018 Ram 2500
Ohio River Rat
12-02-2020, 10:58 PM
#778
YIKES! Thank goodness for insurance. Weren't you considering a 2nd AC unit?
Would this be a good time to do that?
12-03-2020, 07:14 AM
#779
MCTroy
Tuckerdog1 yes, we were considering a 2nd AC. I will ask how much that would be along with new tires. Adding all this we won't be trading this in for a while! Our insurance company has been great along with the RV dealership staff.
2018 Ram 2500
Ohio River Rat
