found the video if anyone needed on how to make it straight again.. I do have a question on the second method.
First method is to back it up so the plate is even on both side then hook it up. Ok this way is doable. But sometime you cannot backup that way because of space on the street.
Method two.
backup the truck to the trailer parallel straight. So on the video the left side is not straight so you unhook the left side chain.
Question is on the right side chain do I tighten it with my my hand and drive to the left so it can go back to normal? or do I leave the right chain loose? anyone know the process to this second method?
thank you
