Old 02-28-2017, 10:58 PM   #21
Digital thermostat?
Originally Posted by Frenetti View Post
I have the same trailer and had the same issues, I sealed all holes the same way, amazing the size of some of the holes they cut for rather small items, the one under the tub was massive. I also changed over to a digital thermostat, I was told by a tech that variance between the digital and and dial/lever could be as much as 4-5 degrees. Lastly I found when I took off the cover for the A/C inside the camper there was air leaks in the unit and the return air, cold a/c air was being sucked into the return and icing up the unit, lowering the effectiveness of the unit. I was able to use a HVAC tape and seal the leak. Once I did all these I have never had another issue
Frenetti, how did you replace your thermostat? Where did you get it from?
Hman0109 is offline   Reply With Quote
Old 02-28-2017, 11:18 PM   #22
Easy instal, took 15 minutes. Wires are labeled so it was an easy swap out. I believe the new digital thermostat was $40-$50, found online, I simply replaced my Coleman Mach manual thermostat with their Digital version. Nothing fancy, I read different mods where guys are using home use thermostats to be able to have the programable features. The install made a big difference for me, the variance in a digital thermostat is 1-2 degrees versus 4-5 in a manual.
Frenetti is offline   Reply With Quote
Old 03-01-2017, 01:13 AM   #23
Herman:
If you have a Coleman-Mach, see the attached. I used a Honeywell from Home Depot, but the pic should help you with about any model. You do have to add the switch if you want hi/lo fan speed. If that bothers you, you can go with the Digital Coleman-Mach, which will be plug-and-play, but cost you more (and I don't think it's programmable).
2011 Traverse LT, 3.6L, FWD
