I have a 2013 Rockwood Mini Lite and want to install a backup camera. Tried to install it just below the middle clearance light and use the clearance lite wires but there is a shelf just under the light and can not feed the camera wires up to the light wiring. Any suggestions on how to install??
What is on the inside wall behind the clearance light? Maybe you can punch through the inside wall and go back out under the "shelf" in the wall. Then cover the wire with a piece of trim or moulding.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
