Old 02-18-2017, 07:33 AM   #1
Barbecue Grill outside
I have in my 8289 a gas line on the right hand side and a bracket or some-kind of holding piece of aluminum for a grill.
Does anybody knows where to buy the grill that attached to it?
Hman0109 is offline   Reply With Quote
Old 02-18-2017, 07:39 AM   #2
Georgia Rally Coordinator
aceinspp's Avatar
You could probably buy from dealer however are you sure that it did not come with the camper when you bought it or was it an option. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Traded 2015 30WRLIKS V-Lite
Days camped 2018 67
Days camped 2019 62
Old 02-18-2017, 08:14 AM   #3
wmtire's Avatar
It is an option on some RV's and sometimes the dealers don't have them included in the RV. My Flagstaff (sister line of Rockwood) did have the sidekick grill/bracket in a storage compartment when I purchased it.
Here is one place to get it, if you want it. I also see them pop up on our classifieds here on the forums from time to time, where members don't want theirs.
Sidekick Grill – Outdoors Unlimited, Inc.
Just remember that whatever grill you do get, that it needs to be what is called a low-pressure grill in order to use it with the grill hose already on your RV. This grill hose is going thru a regulator, and a low pressure grill doesn't have a regulator.
If you buy a Coleman or many other grills that have a built-in regulator, then when you try to connect them to this hose,...... it's basically being double regulated, and the flame will stay low.
We have many threads on how to adapt for this, by either removing the grills built in regulator, or running a hose direct off your propane tanks before the low pressure grill hose regulator. Doing a forum search will be your friend if you decide to use something besides the sidekick grill or similar.
Here are a few:
http://www.forestriverforums.com/for...ml#post1267790
http://www.forestriverforums.com/for...tml#post921009
Hope this helps
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 02-18-2017, 09:02 AM   #4
Thank you Buddy. Great info.I do have a Coleman; so I wont be able to use it.
Old 02-18-2017, 09:29 AM   #5
wmtire's Avatar
You can with either a grill regulator modification (to use the low pressure line) or tap into your propane tanks and run a line from them.
We have many threads on both.
Geaux Tigers!!!!
Old 02-18-2017, 09:33 AM   #6
I modified my coleman road trip to run off the qd gas connection, it's not hard.
The grills that come with trailers are junk. I never did like the idea of attaching a grill to the side of my trailer anyhow. I modified my grill bracket into a bracket to put my tv outside.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 02-18-2017, 09:41 AM   #7
DaveSchwartz's Avatar
If you do plan to buy the original Sidekick type you might want to at least go for the stainless steel version. The OEM black version is just thin stamped steel and after 3 seasons of only light use is showing heavy rust, the burner cover is holed and loose and the rack is completely rust covered. The Sidekick SS is the exact same look, just with the parts stamped out of stainless so I really can't say I'd really recommend that either. Camco makes a model called the Centurion that looks much beefier and is compatible with the low-pressure system and mounts to the rail.
Myself, I bought a NexGrill portable from Costco... completely decently thick SS and the rack is built of beefy SS rod. I've thought about adapting it to the low-pressure system and mounting rail but will use it on a table (built-in, fold-out legs) for now because I already have high-pressure Extend-A-Stay hose on the door-side LP tank for a propane firebowl.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 02-18-2017, 09:49 AM   #8
Flybob's Avatar
I have never been a big fan of a grill attached to the side of my RV. You might consider a stand alone table top grill as you have many more uses ( power outages at home, picnics) and many more choices. Most of the grills and stoves that I have seen included with units have been lower quality and performance.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-18-2017, 10:04 AM   #9
tmfaulksr's Avatar
I have a 2015 8289ws Diamond pkg & the grill was lost but the table was kept.
I kept looking and pricing while waiting patiently for one to show up on some local
classifieds & here on FRF.
I purchased an "unused sidekick grill" on these FRF classifieds 3 days ago.
The stock picture of the grill on a camper is from the web that shows setup.
The other grill picture shown was given by my fellow FRF member that sold it
and the propane hose picture is my camper :-)
The picture of us camping was 2 weeks ago and can't wait to try out the grill.
THANK YOU FRF
ID:	130122   Click image for larger version
Name:	Screen Shot 2017-02-15 at 9.46.27 AM.jpg
ID:	130123   Click image for larger version
ID:	130124   Click image for larger version
Name:	Screen Shot 2017-02-18 at 8.55.37 AM.png
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 02-18-2017, 10:31 AM   #10
Thank you for the brilliant example of using a power cord hatch to run the propane hose. I was always dissatisfied with having to leave my propane bottle door open to run out the Extend-A-Stay hose and this will make that very tidy indeed.
Obvious in hindsight, as they say.
Old 02-18-2017, 10:52 AM   #11
Mddle of the Rd Extremist
MeepMeep's Avatar
X2!
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 02-18-2017, 11:12 AM   #12
Left Coast
This Rockwood came with the hatch as standard equipment......now being used for a door to connect outside coffee pot water
Old 02-18-2017, 11:33 AM   #13
Nurek's Avatar
That grill (same pictured above) that came with my Rockwood is total garbage.
Mine is sitting in my storage locker and you can have it.
I've been grilling for 30+ years and this "grill" will disappoint you after the first run.
I cooked a steak on it.... the whole thing was well done and not a single grill mark was burned onto it. The bbq sauce didn't even get hot. You see... the problem is that the element is about 2" below the grill and destroys anything you cook. I'd say it is only worth cooking hot dogs on.
Get yourself a set up like I did and you won't be disappointed.
Camp Chef Stove and GrillBox30. The Grillbox is infrared cooking and is reallllllly good at it. Plus it can double as a stove to cook a pizza or w.h.y.
You will need to remove the stoves regulator and replace it with a new hose and connectors.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 02-18-2017, 11:34 AM   #14
Butch Wilson's Avatar
I use mine for every meal . When the time comes I will replace it with the same one.
Butch Wilson
2016'Flagstaff T21QBHW A-Frame
Butch Wilson is offline   Reply With Quote
Old 02-18-2017, 09:21 PM   #15
KAISOR's Avatar
Fantastic!!!!! Will try this!!
KAISOR is offline   Reply With Quote
Old 02-18-2017, 09:23 PM   #16
KAISOR's Avatar
You can also use it on a table with the bracket.
Old 02-18-2017, 09:24 PM   #17
KAISOR's Avatar
Old 02-18-2017, 09:31 PM   #18
RangeMaggotBob's Avatar
THANK YOU FRF
EDIT: I guess the pic didn't come through, but I think you know which one I mean.
That one in the bottom pic is the one that SHOULD have come with your RV. I have the same model- 2015 8289- and that's what came with ours. For us, it's been a pretty decent BBQ. (If you're from out West, that's what we call grills.) Call your dealer.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 02-18-2017, 10:03 PM   #19
BandJCarm's Avatar
FYI, I do 99% of all cooking outside.........smoking, grilling, frying, whatever.
I just got this one.........looked at the Weber Q grills.....which are probably a tad bit better made, but not big enough inside, and ran on 1 lb propane bottles. And more expensive. This one runs on full LP bottle. I carry one extra in back of truck, in a milk carton. This one will smoke, or grill, or both. I cooked burgers on it with the smoke tray full also, and man.......what a great flavor the smoke tray adds. And it fits in the basement. Don't know how well it'll hold up.........will have to see. But it solved all my grilling requirements, and is a smoker too (though I wouldn't try and smoke a brisket for 12 hours on it, or anything similar)........
Vector Gas Tabletop Grill with Smoke Tray - Outdoor Leisure Products VT280RDS - Gas Grills - Camping World
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-19-2017, 07:06 AM   #20
SYE
SYE's Avatar
Green Mountain Grill
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
