If you do a search on plumbing threads you'll find it. If you look in under the access panel, around the drain you'll see the area around the drain going into the tank is pretty much unsupported. Not a whole lot of room to work in. I noticed this soon after I got the TT, that there was a lot of flex to the floor area around the drain as you moved around in the shower. Figuring this was not going to be good long term, I bridged over the drain area( I used a sheet of ABS, undoubtably you'll end up with plywood), supporting the bridge with EPF foam which can be compressed for installation and will expand back to a tight fit. I usually come onto the foam as a packing material. It takes about 90% of the movement out. If they put you in a new pan, you might want to consider this.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
