Old 02-06-2021, 02:16 PM   #1
MontanaCamper's Avatar
Battery Charging Port?
Am wondering about using this solar charging port on my camper as a convenient place to plug in the 12 volt cord on the generator. And would it be best to wire in a solar controller to monitor and regulate the charging. Comments please. The 2104S came pre-wired with this solar hookup
2021 F150 4x4 3.5 Ecoboost 3.55 Gearing
2021 Rockwood 2104S
MontanaCamper is offline   Reply With Quote
Old 02-06-2021, 02:22 PM   #2
I’m watching this post. Seems like a great idea unless I’m missing something. My Battery Tender monitors the charge rate and comes with the male connector for that solar port.
Dirtyspokes is offline   Reply With Quote
Old 02-06-2021, 02:40 PM   #3
Chuck_S's Avatar
12vDC will not charge your trailer battery it needs at least 13.7vDC Don't use the 12v outlet on the generator for this. Solar cells put out more voltage than 12vDC but few amps so they're trickle chargers at best but can trickle for days.
To charge your battery just connect your generator's AC outlet directly to the trailer's shorepower inlet and let your builtin battery charge do it's job. Can still take several hours but not days.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 02-06-2021, 05:04 PM   #4
I know this generator will charge batteries as have used it to do so, once used it to charge the 2 big batteries on my Versatile tractor after having left the cab fan on, it took a long time but those batteries are large. The generator ouput at 12 volts is 6.3 amps. Is it exactly 12 volt? I don't know.
2021 Rockwood 2104S
Old 02-06-2021, 05:12 PM   #5
bikendan's Avatar
Plugging the shore cord into the generator and letting the RV's converter/charger recharge the batteries will be 100x more efficient than what you're thinking about.
Old 02-06-2021, 05:16 PM   #6
On most generators these 12 volt outlets are unregulated and relatively low output. Meant to be more of an emergency charging source to get an engine started.
As mentioned, just plug shore power cord into generator and let the converter do the work. Will do so faster and safer.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 02-06-2021, 05:40 PM   #7
Yes you can. These connectors are just 2 wires to the batteries. But as mentioned plugging your camper into the AC power will be much faster. Many campers have 55-75 amp converters which charge much faster, at least when in bulk mode. It is possible your 12v output may actually charge faster the converter after the first few hours.
2021 Sunseeker 2860DS
HiTech is offline   Reply With Quote
Old 02-13-2021, 11:50 PM   #8
If you try it, verify the polarity. I've read many times that these GoPower fittings are wired in reverse
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 02-14-2021, 08:49 AM   #9
After reading the comments it is apparent to me that I won't be using the GoPower Solar connection for charging the batteries, that I am much better off connecting the generation to the 120 volt shore power terminal and letting the converter send the 12 volt charge to the batteries. The converter provides a staged/tapered charge to the batteries, starting out with a higher amperage and tapering off as the batteries reach the full capacity. Thanks to all that responded.
2021 Rockwood 2104S
battery, charging
